Home > Technical (L322) > 2011 L322 4.4 TDV8 Correct Battery Specification? |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 808 |
I replaced my old battery on my 2004 L322 with a Type 19 95Ah Bosch Lead Acid one
19th Apr 2024 9:58am |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 |
An 019 is the correct specification.
19th Apr 2024 10:00am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3203 |
Search the part number online and do a cross reference check on the spec. 2012 TDV8 Vogue (L322) |
19th Apr 2024 10:42am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
I think the early 4.4s didn’t have AGM and there was a bit of a recall or such like, then AGM fitted from factory. Happy to be corrected.
19th Apr 2024 11:08am |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 550 |
HI got a wet battery, Exide, 1000, 100ah, 900cch 019 battery as opposed to an AGM battery. I rarely get more than 20 mins or radio use after turning off the engine before I get the "low power - shutting down" message.
19th Apr 2024 11:14am |
I fitted a new Varta G14 AGM to replace a 6-month old 'Napa AGM' battery (fitted by previous owner probably from Kwik-Fit) and it immediately cured my premature FBH shutdowns and low battery warnings after listening to the radio for a few minutes.
19th Apr 2024 11:34am |
I personaly wouldn't fit a non AGM battery to a 4.4 but this won't help with the shutdown issue after 20mins as this is just to do with the capacity and the way the power is managed by the ECU. 2012 TDV8 Vogue (L322) |
19th Apr 2024 11:47am |
OK, thanks for that feedback, much appreciated
19th Apr 2024 12:30pm |
