Home > Technical (L322) > Harsh kickdown
JW911
Harsh kickdown
I’ve noticed a few times if I use kickdown, it seems to change down, the engine spools up to silly revs and the gear engages after a pause with quite a thump, with the torque converter stinking for a period afterwards. Dropping two cogs with the paddles doesn’t cause the same issue. Any ideas, please? Gearbox software or something?
i know the 405 with this engine and gearbox combo (4.4TDV8, ZF8) can have a similar issues. How do I fix it, other than not use the kickdown. 2021 3.0 P400 Vogue - coming!
2012 4.4 TDV8 Westminster - going!
2007 3.6 TDV8 Vogue - gone!
2003 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #678583 23rd Nov 2023 2:37pm
CS
My 405 had something similar. The gearbox software was re-done and that seemed to cure it. I think there was a "service bulletin" issued by LR about that known fault, though no recall, i.e. it would be done for customers who complained about having that problem, not automatically on annual service or the like.
Maybe see if there is something like that for the 322 also? Only Range Rovers since 1988
Post #678603 23rd Nov 2023 5:50pm
JayGee
There is a gearbox software update available and Glenrands will do it for a fee but that sounds not right to me and didn't happen to mine before I had the software update. Have you checked the fluid level in the gearbox and /or had it serviced at all? 2012 TDV8 Vogue (L322)
Post #678622 24th Nov 2023 10:41am
D3Jon
Re: Harsh kickdown
Surprised you can smell the fluid when driving, it must be getting pretty well cooked. Sad
Transmission fluid could be burning from slipping clutch packs or overheating from a sticking thermostat block.
Have you some diagnostics kit that you can monitor transmission fluid temperatrure with?
How many miles on the gearbox?
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #678637 24th Nov 2023 1:48pm
JW911
The smell was a one off after parking.
Gearbox is 77000 miles with a full fluid change a couple of years ago. 2021 3.0 P400 Vogue - coming!
Post #678671 25th Nov 2023 7:34am
D3Jon
Wow, low miles and well maintained, don't know what to suggest in this case. 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Post #678736 25th Nov 2023 9:54pm
JW911
I’ll go down the software update route initially I think. My specialist has the kit so he tells me. 2021 3.0 P400 Vogue - coming!
Post #678810 26th Nov 2023 10:26pm
JW911
A reflash seems to have cured it. Should get chapter and verse from LR next week.
I went up to 55 profile tyres from 50s a little while ago, which probably had something to do with it. Apparently the car now knows the new tyre size. 2021 3.0 P400 Vogue - coming!
Post #679295 2nd Dec 2023 12:09pm
JayGee
The car needs manualy programing for 55 tyres as the speedo will be bang on and not the standard over reading. Some like it like that though. Gear changes may be different as the load is higher but not sure if any of the other input parameters in the GAP IID do anything but it's probably best to set them up for the exact tyre size as things like ABS and traction control may be effected? 2012 TDV8 Vogue (L322)
Post #679344 3rd Dec 2023 2:30pm
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys got some issue here when car is cold hesitates changing from 2nd to 3rd gear hard downshift from 2nd to 1st only does this once once car is warmed up no hesitation form 2nd to 3rd but I do notice a bit of dancing about on rev needle when changing in gear 2nd to 3rd. Had the gearbox software update from Gap didn't make any difference. The car also has the bang clunk when on kickdown feels like bottom of car in centre. Had transmission oil change and transfer case oil change no difference. Any other options to explore greatly appreciated. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #690886 19th Apr 2024 9:53am
JayGee
Probably best to ask in the L405 forum but from the sounds of it I'd be seeking a diagnosis from a ZF qualified gearbox specialist. 2012 TDV8 Vogue (L322)
Post #690889 19th Apr 2024 10:08am
