![]() | Home > Technical (L322) > Harsh kickdown |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
My 405 had something similar. The gearbox software was re-done and that seemed to cure it. I think there was a "service bulletin" issued by LR about that known fault, though no recall, i.e. it would be done for customers who complained about having that problem, not automatically on annual service or the like.
There is a gearbox software update available and Glenrands will do it for a fee but that sounds not right to me and didn't happen to mine before I had the software update. Have you checked the fluid level in the gearbox and /or had it serviced at all? 2012 TDV8 Vogue (L322) |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 513 ![]() ![]() |
Surprised you can smell the fluid when driving, it must be getting pretty well cooked. ![]() Transmission fluid could be burning from slipping clutch packs or overheating from a sticking thermostat block. Have you some diagnostics kit that you can monitor transmission fluid temperatrure with? How many miles on the gearbox? Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 260 ![]() ![]() |
The smell was a one off after parking.
Wow, low miles and well maintained, don't know what to suggest in this case. 1992 RR Classic 3.9 efi Vogue
I’ll go down the software update route initially I think. My specialist has the kit so he tells me. 2021 3.0 P400 Vogue
A reflash seems to have cured it. Should get chapter and verse from LR next week.
The car needs manualy programing for 55 tyres as the speedo will be bang on and not the standard over reading. Some like it like that though. Gear changes may be different as the load is higher but not sure if any of the other input parameters in the GAP IID do anything but it's probably best to set them up for the exact tyre size as things like ABS and traction control may be effected? 2012 TDV8 Vogue (L322) |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Hi guys got some issue here when car is cold hesitates changing from 2nd to 3rd gear hard downshift from 2nd to 1st only does this once once car is warmed up no hesitation form 2nd to 3rd but I do notice a bit of dancing about on rev needle when changing in gear 2nd to 3rd. Had the gearbox software update from Gap didn't make any difference. The car also has the bang clunk when on kickdown feels like bottom of car in centre. Had transmission oil change and transfer case oil change no difference. Any other options to explore greatly appreciated. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Probably best to ask in the L405 forum but from the sounds of it I'd be seeking a diagnosis from a ZF qualified gearbox specialist. 2012 TDV8 Vogue (L322) |
