Home > Technical (L322) > 322 stranded and 8 weeks later...finally repaired
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
First time in my life I had to be towed away with a break down. (had 5 Range Rovers) 300 km from home parked the car at the hotel, next morning, key in contact, dash reacted normal, turned the key, nothing happened. Breakdown service couldn't find a problem. Car off to towing station and we heading home in a rentalcar.
3 days later garage phoned and had no clue, car still "dead". Had it moved to an "electrics specialist" near my home in Perigueux, now 6 weeks later (yes I live in France where they eat snails) still no progress. They can't find anything.
I did a hard reset,
checked the (nearly new) battery,
changed key
GAP gives no faults
they took out the electronic unit on the starter that prevents the car being started (alarm) send it away for a check up, nothing wrong.
they can't find anything on their diagnostic programs (four different ones)
Today they phoned me and told me they feared that there was nothing they can do... Big Cry
any amongst you with a bright idea or same experience???
Any help will be largely appreciated
Post #690422 11th Apr 2024 5:52pm
ignition barrel? ... - .- -.
Post #690430 11th Apr 2024 7:20pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Hi Robert,
This happened to me and after weeks of head scratching I put a live onto the starter motor when the ignition lights were on and it started as normal.
I ended up wiring a press to start switch into the car which is still being used today. However, I should’ve tried Stan’s suggestion of trying a new ignition barrel.
Hope this information helps?
Regards
John
Post #690435 11th Apr 2024 8:02pm
ballast
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
I think you've got to go back to basics and agree with the comments above. Fundamentally, regardless of the electronic complexity, the starter needs 12V to turn it over, if that isn't happening, there's not many things prior to that which control the 12V being presented that aren't CPU controlled, the ignition and immobiliser being two of the most significant, but also, bad earth, poor +ve connection, etc. will have same impact and won't show as a fault regardless of what fault reader you use.
I'd get a simple multimeter and check the basics working back from the starter motor. If it's not a recorded fault, a CPU isn't 'seeing' an error in the data it's receiving and if that's the case, for me it points to 'simple' hardware failure (i.e. non CPU linked) or poor connection.
Don't forget the starter motor pulls big power when you crank and a loose connection might look OK but be insufficient to crank.
Hope that helps and good luck
Post #690436 11th Apr 2024 8:38pm
Robert
Thanks guys, Bow down Bow down first thing tomorrow, call the Frenchies.... Cool
and I did tell them to use a live cable directly to the starter, it worked...so nothing electronic, turned out to be the mass cable from the engine to the bodywork. So basic work for a mechanic, but hey who can nowadays set a carb without a computer...?
Funny thing, I told them from the beginning look at the mass cables....."non c'est impossible, monsieur"... Mr. Green
So I can pick her op tomorrow Thumbs Up
Thanks for the tip guys!!!
Post #690438 11th Apr 2024 10:18pm
Robert
and yes, I did tell them to use a live cable directly to the starter, it worked...
They called me this morning that the car was repaired. When I asked what was wrong, they told me (sotto voce) that it turned out to be the mass cable from the engine to the bodywork.
So basic work for a mechanic, but hey, who can nowadays set a carb without a computer...?
Post #690791 17th Apr 2024 4:37pm
pcourtney
what is a "mass cable" ?
do you mean an earth/ground strap to the alternator was missing and needed to be fixed on ( or tightened up in order to operate correctly ) ??
Post #690792 17th Apr 2024 4:55pm
GraemeS
Australia
I suspect mass meaning major, being the main earth strap.
Post #690799 17th Apr 2024 9:31pm
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
The French refer to 12V negative as 'masse', if I remember correctly.
So yes... negative cable was the issue. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #690803 17th Apr 2024 11:16pm
Weegie
Yes earth strap.
Very Happy John
GAP iiD BT-Sold
Post #690814 18th Apr 2024 7:56am
Robert
Embarassed Embarassed Embarassed Embarassed Embarassed
yep, I get messed up sometimes. Ground is "terre" in French that's what you use for a cable that connects the electricity in your house to the ground, "masse" is the connection between car body/chassis and F.E. the starter or alternator etc.
Speaking 3 languages everyday makes me a dummy, a Dutchman in France.
But I'm glad you are all there to correct me Laughing Thanks! Bow down Bow down
have a great day
Robert
Post #690816 18th Apr 2024 8:26am
