![]() | Home > Technical (L322) > 322 stranded and 8 weeks later...finally repaired |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35597 ![]() ![]() |
ignition barrel? ... - .- -.
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 340 ![]() ![]() ![]() |
Hi Robert,
ballast Member Since: 18 Feb 2016 Location: Midlands Posts: 46 ![]() ![]() ![]() |
I think you've got to go back to basics and agree with the comments above. Fundamentally, regardless of the electronic complexity, the starter needs 12V to turn it over, if that isn't happening, there's not many things prior to that which control the 12V being presented that aren't CPU controlled, the ignition and immobiliser being two of the most significant, but also, bad earth, poor +ve connection, etc. will have same impact and won't show as a fault regardless of what fault reader you use.
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2290 ![]() ![]() ![]() |
Thanks guys, |
and yes, I did tell them to use a live cable directly to the starter, it worked...
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 899 ![]() ![]() ![]() |
what is a "mass cable" ?
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2637 ![]() ![]() |
I suspect mass meaning major, being the main earth strap. |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
The French refer to 12V negative as 'masse', if I remember correctly.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3254 ![]() ![]() ![]() |
Yes earth strap.
