![]() | Home > Maintenance & Mods (L322) > JXB Performance Driveshaft Carrier Upgrade |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 194 ![]() ![]() ![]() |
So, it appears that I might be the first on the forum to upgrade their propshaft/driveshaft carrier using the JXB Performance Driveshaft Carrier. If not the first to upgrade, I’m certainly the first to make a post about it as can’t find anything else on this forum.
I’ve noticed two symptoms that are related but not the same.
One final post to close this down from my side: I’ve now managed to replace the propshaft bearing. And, great news, I now have a silent running and very smooth driveline again.
BCrover Member Since: 02 Aug 2012 Location: Canada Posts: 2 ![]() ![]() |
Great post, just ordered mine. Fingers crossed the bearing is good. Were you able to spin the bearing once cut away down the oem rubber in the carrier? |
Yes, the bearing will almost certainly still spin on prop shaft after you cut away the metal frame and trim back the rubber surround ready to fit the JXB. It’s at this point that you need to pay significant attention to the bearing. Spin it on the prop and if it is anything less than buttery smooth then you will likely need to replace the bearing too by splitting the prop. Any roughness or feeling like there is even the slightest of grinding and the bearing has basically failed and should be replaced.
ok thanks for the reply. I will have a bearing on hand I guess, and if the one in there is not perfect I will replace. Did you use new bolts for the driveshaft or re-use the existing ones? |
No reason why driveshaft bolts can’t be reused as not high-torque stretch bolts. Andy
tomiRR Member Since: 06 Jan 2025 Location: Europe Posts: 15 ![]() ![]() |
Dear Ajmngn,
Hi Tom,
Hey Andy,
Dear Ajmngn,
If it was me, I would install the JXB carrier now for 2 reasons:
Dear Andy,
