Home > Maintenance & Mods (L322) > water dripping from underside of glovebox |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
If indeed your ac drains are blocked it’s possible the water is from the ac evaporator tray overflowing. If it’s not that it definitely sounds like your windscreen leaks somewhere. |
14th Apr 2024 4:31pm |
joeypineapplez Member Since: 27 May 2015 Location: Waterford Posts: 68 |
Thats something I hadnt thought of, thanks. Not sure where that is located but I will find out. Im hoping its not the screen 2002 TD6 Epsom Green |
14th Apr 2024 4:37pm |
TST717 Member Since: 18 Oct 2014 Location: Inverness Posts: 34 |
I have just had the same issue on a Cayenne …same symptoms and this was the issue …..stripped out the evap plastic pipework , cleared drains , hopefully stays cleared , replaced the cabin filter at same time ….. re-installed in reverse … job done … There is usually lots of guidance on YouTube or on here for the RR …. T |
14th Apr 2024 7:02pm |
You don’t need to get to the evaporator, which is a serious job, just concentrate your efforts on clearing the drain pipes and the tray will empty as normal. |
15th Apr 2024 7:25am |
Hmmm,
15th Apr 2024 7:37am |
Well I had a bit of a poke around today and the AC drains are clear and flow beautifully. I lifted the carpet as best I could and the wetness is confined to passenger footwell only. Next area for investigation is the screen. Hard to see any leaks at the bottom of the screen with all that dash in the way.
15th Apr 2024 12:16pm |
Did a bit more stripping down this evening. I can see where the water has tracked down the metal dash supports and landed on the back of the glove box. Cant see much more than that at the moment as behind the dash is a very busy place.
15th Apr 2024 4:54pm |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 334 |
Well done. Perhaps try some water on the windscreen? |
15th Apr 2024 7:42pm |
And cover the fuses first! Have you disconnected the battery? |
15th Apr 2024 7:44pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1236 |
Could it be as simple as a sticky patch as seen on 'LR Time's Discovery' behind the A pillar cover? |
15th Apr 2024 8:23pm |
Yeah Ive seen that LR time episode and was hoping it would something simple like that. Today I made a rain testing rig. Its on the go there at the moment. Im gonna let it run for half an hour and then investigate.
16th Apr 2024 11:35am |
Well after some extensive testing Ive finally found the source of the leak. Its not what I expected. During my "rain shower" I noticed water dripping off my curtain airbag. I followed this tiny trickle back to the upper corner of the passenger side windscreen.
29th Apr 2024 5:00pm |
LFREE22 Member Since: 25 Apr 2023 Location: Aberdeenshire Posts: 8 |
I would suggest Stixall sealant. I've used it for loads of things from sticking air vents on the exterior of my house, to bonding garage door seals to the ground. It seems to be indestructible from what I can tell. |
13th May 2024 1:44pm |
