Home > Maintenance & Mods (L405) > Corroded Brake Discs 2021 RR
RR4.4
England 2019 Range Rover Vogue 3.0 SC V6 Santorini Black
Recently bought the car (long distance sale), have been noticing a burning smell and upon checking the discs appear woeful... Thoughts?
Post #690607 14th Apr 2024 5:41pm
garyRR
It's quite normal for the outer edge of a disc to rust, especially the cheaper ones.
Ebay specials and Euro Car Parts crud love a bit of corrosion.
It's difficult to see in the photos the level of lip that's built but, but I can see scoring on those discs however - if in doubt, just change them. Discs and pads aren't an expensive outlay on such a vehicle. 2015 Range Rover Autobiography 4.4 SDV8
Post #690641 14th Apr 2024 11:18pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, If you spin the disc against a screwdriver or chisel levered against the brake caliper most of that edge rust will flake off.
There isn't much of a lip on either the outer or inner edges from what I can see, however, you do have scoring so a stone or something has got itself trapped in the pads at some time, may not be there now though.
I'd say change the discs for sure, scrub the pads to ensure flat if they're recoverable and a lot of life left in them, but it would be better if you changed the discs and pads then you have peace of mind.
Me personally, I'd replace the discs and pads with a good brand like Pagid or Brembo. You can paint them when new in VHT enamel, (not the disc faces though) that will prolong the life from the rust, but although unsightly it doesn't pose an integrity problem to the disc itself.
Andy Fuji White 2012 4.4 TDV8 Westmiinster
Post #690648 15th Apr 2024 8:58am
