Home > Technical (L460) > L460 PHEV Battery Charging For Best Results / Extended Life
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
Update - Answer found through Google:
"Keeping the battery at 30%-80% charged and minimizing the number of charges - vs charging the battery to 100% and/or charging every drive cycle - will keep the battery performance in optimal condition".
Post #690042 6th Apr 2024 8:42am
Tom1010
Yes it says that on the Land Rover website: https://www.landrover.co.uk/ownership/phev...-life.html
I do all my charging at home overnight on cheap rate electricity and charge to 100% everytime. The one thing I have started doing is charging slower, between 6-10A rather than 32A. Will it help? I probably won’t keep the car long enough to find out!
Post #690472 12th Apr 2024 11:37am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
No it wont help, consider the current when discharging it can easily reach hundreds of amps so 32 amp whilst charging wont put any significant stress on the systems. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #690498 13th Apr 2024 4:17am
Jaggers123
Hi all,
I recently took delivery of a 2024 P460e, which I absolutely love!
It is my first electrified vehicle so I got a three phase Andersen A2 charger installed at home along with a tethered 22kW cable. We have a three phase supply and Andersen have confirmed that their remote diagnostics show the charger has been connected correctly.
When I charge my P460e, the maximum charging speed is 7.4kW and this takes about 4 hours to charge a flat battery. I was expecting 22kW. Andersen are saying that the speed may be restricted by the onboard charger in the car. When I have charged at fast chargers, I have had 50kW, although I appreciate these are DC rather than AC which may be the reason.
Is anyone able to charge at home at 22kW speed?
Thanks in advance!
Post #692704 15th May 2024 12:38pm
Martin2
Looks like 7kw AC might be the Max for the onboard charger?
 MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #692735 15th May 2024 7:16pm
Jaggers123
Thanks @Martin2 - you are absolutely correct. I have now also had this confirmed from the Range Rover Relationship Manager at the Range Rover Studio in Solihull where I collected the car.
A bit disappointing that they didn't go for a 22kW onboard AC charger. I'm guessing they will put this into the fully electric variant.
Post #692782 16th May 2024 2:04pm
