Home > In Car Electronics (L322) > Anyone done the UAD CarPlay Upgrade (2012)?
JW911
Considering doing this to my Westie:
https://unique-ad.co.uk/product/wireless-a...2009-2012/
Has anyone done it? Can/will a typical ICE dealer fit it?
Thanks. 2021 3.0 P400 Vogue
2012 4.4 TDV8 Westminster - gone!
2007 3.6 TDV8 Vogue - gone!
2003 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #690133 7th Apr 2024 7:55am
PeteT80
&t=41s
Post #690134 7th Apr 2024 8:12am
garyRR
No typical dealer will fit, nor car audio places. You need a specialist who has fitted them before.
To be aware obviously that the carplay is on a low resolution screen not much bigger than today's phones.
On my L322 I went for the screen replacement option:
 2015 Range Rover Autobiography 4.4 SDV8
Post #690137 7th Apr 2024 8:43am
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Gary the screen you have fittted looks good, I’ve got couple of questions;
Does it still pop the reversing camera up when you select reverse?
Perhaps the most important one as I’m looking for a solution for my dads L322 who won’t want to stream music/radio from is phone does the updated screen have a way to play the stock FM tuner or even does the screen have a FM tuner built in so you can listen to the radio whilst using Waze or Google maps for your navigation.
Post #690330 9th Apr 2024 5:28pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
I’ve had a UAD CarPlay system for just over a year; it works well in general but has some small glitches:
1.) the microphone on the UAD system seems to get conflicted with the incar system when making calls or sending voice notes. For example “Hey Siri, play music xyz” works fine. “Hey siri call home” seems to work most of the time, reliability of incoming calls is a bit flaky but using Siri to do speech to txt for the body of a txt message does not work in my experience.
2.) The installation is dependent on a loop back plug in the audio-in of the rear passenger console. This is a bit cludgey and I’m convinced that one day this will get kicked out and lost for ever.
3.) Agree 100% with @GaryRR on the screen upgrade. Mine is on the OEM screen. It’s okay but I wish I had a full width touch screen only without side buttons.
The main advantage for me is upgraded Navigation apps, Apple Music, podcasts and audible. Well worth it for that.
Lastly, try looking up Lee Yates of UK Light Modifications on Facebook; he travels around the county doing loads of these installations. I have no experience with him specifically but he seems to do 2 or 3 installations a week and there’s an advantage in having someone who does the installation regularly. TDV8 4.4 2012
Post #690332 9th Apr 2024 8:20pm
garyRR
Yes, the reversing camera still pops up, and it has an FM tuner built in. You have the choice of using CarPlay or downloading apps (e.g. Google Maps, Spotify) directly to the screen and using that as the Infotainment system. 2015 Range Rover Autobiography 4.4 SDV8
Post #690333 9th Apr 2024 8:37pm
Jamiehol
Gary thanks for that, gives me an option I’ll take a look on Ali Express and see if I can find a screen.
Post #690339 10th Apr 2024 6:50am
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
you loose front /rear fader, enabling/disabling Logic7. cd player, RSE control.
Post #690340 10th Apr 2024 7:17am
Jamiehol
That’s fine in my use case or to be precise my OAP dads case as long as he can still listen to Radio 2 or 4, still having a working reversing camera via the screen but have updated sat Nav via using Google maps or Waze he will be happy.
He hasn’t got RSE, never touches the fadar and I don’t think he has ever put CDs in the CD changer.
Post #690373 10th Apr 2024 8:29pm
th3chainrule
United States
How is the sound quality? Is the audio still transferred via the fiber optic MOST?
Post #692733 15th May 2024 6:09pm
Andyyav
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
I have the unique audio / IDCore install in my new to me 2011 4.4, agree with Ramblin man on the aux plug, think I’ll hide that connection up some how, only issue I’ve found so far is sometimes the phone doesn’t connect calls but they show on the screen, (quite possibly user error) I still have full access to the standard screen and menus
Have a look at CDS over on the disco 4 forum he regularly installs these and may have other options?
If you’re feeling brave you can install it yourself it does involve taking the screen apart to add a ribbon cable…… 1972 Series 3 full of character
1985 90 pick up went anywhere
1992 90 Exported
2007 L322 that was an experience
2010 D4 more versatile than a Swiss army knife, now gone
2011 L322 4.4 VSE
Post #692747 15th May 2024 8:48pm
JW911
I used my bravery buying a RR in the first place. Laughing
It’s a pretty sorted place to be now after nearly eight years with it. I keep thinking of cleaning the slate and getting a late L405 and an 840iGC but the difference doesn’t justify the expense quite frankly. CarPlay would be handy in both (BMW doesn’t have it either) but I’m sure I’ll survive without it. “Nice to haves” are nice to have but not essential ultimately.
The Lightweight should be with us in the next couple of weeks after a lot of work. That doesn’t have CarPlay either. Wink 2021 3.0 P400 Vogue
Post #693091 21st May 2024 9:17pm
RJDS
United Kingdom 2011 Range Rover Autobiography TDV8 Bournville
I’ve just had Lee Yates fit the IDcore in a 2011 AB. All apps work, steering wheel controls work. Excellent installation work by Lee. If you are going down the IDcore route, I would highly recommend Lee. 2011 TDV8 4.4 AB Bournville Brown
Post #706158 5th Dec 2024 2:54pm
Jimnic007
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Baltic Blue
Just to add to this thread, I had it installed in my L322 and I use it for Android Auto, which works very well for Waze and music streaming etc.
The two issues I find:
1. When I first had it installed the sound quality was terrible, but I worked out that this was down to the fact that the master volume has been set to maximum. Once I reduced this to around 20, it sounded great.
2. The ongoing issue I have is with the phone mic. It has been put in the dash top air vent and the quality is terrible for anyone ringing me. Does anyone know what the cause of this is? Is it the placement of the mic, the quality of the mic or something to do with the two mics (the one for the standard RR audio and the UAD mic) fighting against each other?
Thanks
James
Post #706350 7th Dec 2024 8:05pm
RJDS
Lee Yates mounted the phone mic on the steering column for my installation, seems to work very well. 2011 TDV8 4.4 AB Bournville Brown
Post #706508 9th Dec 2024 11:08pm
