Oil leaking from PCV valve | |
Hi Everyone,
I finally tracked down a small oil leak on my ’09 L322 USA spec (4.2L SC petrol engine).
There’s a small leak on the right-hand side from the hose connection to the PCV valve on top of the valve cover gasket. I figured it would be an easy fix!
I ordered up a new OEM PCV valve that just arrived today. But, it turns out it’s just a hollow plastic body! I’m used to the types of valves that rattle from a ball inside to only allow the fumes to flow one way.
Before I install the new part I wanted to check if there could be some other issue. Seems unlikely that a part with no moving parts would break.
If it’s not the PCV valve, I can still return it since I have not installed it (yea, there’ll be a restocking fee but it’s better than nothing!).
Could it be the “O” ring in the hose that connects to it? Maybe a clog in the hose? I hope that’s not the issue since it looks like a chore to get to the other end of that hose!
Thanks!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
