Home > Technical (L405) > Removing Gear Selector/Shifter |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 119 |
It requires the brake to be pressed to allow you to move it from Park (as you know). I wonder if the switch on the brake pedal is broken thus not allowing it out of Park. I also wonder if the switch is shared with the brake lights and can therefore be tested by simply checking that the brake lights work.
5th Apr 2024 8:32pm |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 |
Yes, you need to remove the center console. There is a good video on Youtube on how to it. ----------
5th Apr 2024 8:42pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1385 |
I think the whole unit needs to be moved. My gear selector was replaced under warranty and the dealer had to replace the lower glovebox lid as the leather had been cut by the unit being moved across. As the dealer did the work I'm afraid I can't say what the steps required are, sorry. Only Range Rovers since 1988 |
Rajah996 Member Since: 04 Mar 2022 Location: Sunny FLA Posts: 6 |
Definitely the gear selector. Already ruled out the brake stop switch in the pedal.
5th Apr 2024 10:21pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
6th Apr 2024 12:13am |
I removed the two you circled, however I dont recall
6th Apr 2024 1:35am |
Once you’ve removed the screws you will be able to lift the rear up and slide it towards the rear of the car. You will then need to turn yourself into a pretzel to unhook the wiring plugs!!! 🔌 |
7th Apr 2024 11:51pm |
