Home > Maintenance & Mods (L322) > L322 spare wheel lifting strap
wizzardofid
2006 Range Rover Vogue SE 4.4 V8 Java Black
Hi,
New on here, owned my fatty for 6 years, never new until the other day that such a thing existed. Has anyone got one for sale? Essex area can collect
Post #579536 13th Jan 2021 12:12am
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
Email Robin Hall at Duckworth LR, he'll sort one out for you.
Just under £50 delivered, 10 minute job to fit it.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #579537 13th Jan 2021 1:28am
robkuijpers
Netherlands
Interested in this as well, what is the LR product number?
As it is nearly impossible to get my 255/50xR20 alloy wheel out of the back. At home I could use some smart lifting techniques, but on the road (when it's raining and dark 😀) I wouldn't be able to get out by myself.
KR Rob 2012 RR Vogue 4.4 TDV8 Sumatra Black
2004 Defender 110 Td5 Epsom Green, 'Alive' Chip tuned and a Warn 8274 Winch
1978 Citroen Mehari Orange Kirghise
2001 Defender 90 Td5 Softop (gone)
1992 RR Classic 300TDi 'Soft dash' Green (gone)
1989 RR Classic V8 Caspian Blue (gone)
Post #689835 3rd Apr 2024 6:08pm
RRDunc
You're going to need:
1 x LKTL000011 (BRACKET SPAR)
1 x LEPX000030 (BRACKET SPAR)
2 x LYYP000400 (BOLT).
The easiest solution is to email Rob Hall (robin.hall@duckworths.co.uk) and mention the FFRR forum.
He'll sort you out.
Post #689842 3rd Apr 2024 7:21pm
mjdronfield
Seems they were standard on early cars but not on the late ones. I’d have taken the one out my TD6 had I have known…..
So easy to get the wheel out using the tailgate as a lever.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #689846 3rd Apr 2024 8:11pm
dhallworth
Robin has left Duckworth’s now, I believe Sophie has taken the reins again.
Post #689847 3rd Apr 2024 8:12pm
robkuijpers
Netherlands
Thanks!
Post #689849 3rd Apr 2024 8:32pm
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
How the lifting straps are not standard anymore is beyond me Question
Why does LR think we have superpowers?
Rolling Eyes 2012 4.4TDV8
2000 Honda S2000
Post #690015 5th Apr 2024 5:06pm
JayGee
Maybe only needed with a full size spare? 2012 TDV8 Vogue (L322)
Post #690016 5th Apr 2024 5:22pm
SpitfireS
It's not maybe! Wink
If the car is fitted with a repair kit only you don't need a lifting strap at all, sure. Razz
In case of a non repairable roadside flat you need to call a flatbed.
With a non full size spare, that I'm going to assume is kinda easy to get out of the boot, you still need to lower that full size flat into the boot = you're gonna need that strap!
Did L322's ever came with a non full size spare or a repair kit?
Mine has the full size spare and it wasn't until I was preparing for a holiday where I was planning to store a studded tire in the boot and 3 in the back so I could swap wheels myself that I REALLY needed that strap.
Luckily I found one on 'the bay of e" as someone on here put it Very Happy
One would expect a LR salesperson to strongly recommend getting the lifting strap once a full size spare is ordered.
In my opinion.
Whistle 2012 4.4TDV8
2000 Honda S2000
Post #690046 6th Apr 2024 8:07am
JayGee
It’s obviously way easier to slide a full size wheel and tyre into the empty space than it is to get it out. To be fair I didn’t find it especially difficult to get the full size out without a lifting kit and only bought one as I saw one going cheap on eBay. 2012 TDV8 Vogue (L322)
Post #690054 6th Apr 2024 8:42am
SpitfireS
Some must have superpowers Laughing
Some don't Whistle 2012 4.4TDV8
2000 Honda S2000
Post #690056 6th Apr 2024 8:51am
JayGee
I'm not especialy strong in the upper body but it helps putting the suspension in access mode and easing the front of the tyre up and working it out gradualy. The strap just makes it faster and easier.
I'm a big advocate of having a full size spare rather than a space saver as a space saver only gets you to your nearest tyre fitter at a slow speed so could end up being a major delay of a journey depending on where you break down, what time of day it is and if the nearest tyre fitter has a matching tyre or pair for the axle. Mind you a full size spare is only of use if you can physicaly change it yourself and even if a breakdown service turns up they may say they can't remove thetyre due to H&S rules..... 2012 TDV8 Vogue (L322)
Post #690059 6th Apr 2024 9:26am
Andy
Having struggled to fit a 21” spare the other day, I’ll be retrofitting a strap. My old 2002 had one and it’s a godsend. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #690063 6th Apr 2024 9:49am
Andy
David.
What’s her email address? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #690064 6th Apr 2024 9:50am
