Home > Maintenance & Mods (L322) > 3.6 tdv8 non dpf - does it have Egr mapped out?
fatu
Czech Republic 2012 Range Rover Vogue TDV8 Sumatra Black
hello all, I am confused with this. My car is factory non DPF so how do I know if my EGR is blanked or not? I would like to do it but I do not know if I even need to do it since non dpf Smile any advice is appreciated, I have iid tool so can I check with this with it? Thanks
Post #689834 3rd Apr 2024 6:03pm
JayGee
3.6 has EGR but no DPF as standard. You can map out the EGR with a software purchase add-on for the GAP tool and fit blanking plates jut to make sure there is no EGR flow. 2012 TDV8 Vogue (L322)
Post #689839 3rd Apr 2024 6:40pm
fatu
Thanks a lot for the info. Is there any way I can check if it is already blanked and mapped out? Just by looking it via gap iid tool?
Post #689840 3rd Apr 2024 6:42pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Take off the engine cover and have a look down towards the egrs. If you can see two of these then it won’t have been blanked off. (I forgot to refit mine when I sold the car to Cinch - oops!)
 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #689882 4th Apr 2024 10:13am
JayGee
Those hoses can be blanked off with plates on the flat flanges and still be in place to pass any nosey MOT tester. 2012 TDV8 Vogue (L322)
Post #689884 4th Apr 2024 10:22am
chris_read
Fair enough. I guess I’m just not as sneaky as some and relied on how MOT testers are not supposed to remove any covers - mine certainly didn’t in the three years after I blanked them. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
Post #689886 4th Apr 2024 11:18am
fatu
Thanks a lot all I will definitely look into under the cover. I thought some simple live view from gap tool would or should tell me but I guess it is not possible. For example when I select DPD values in live view in gap tool it shows n/a, something like that I was looking for. I tried also Egr temp values and they actually show the values so I suspect I still have them, not mapped out.
Post #690010 5th Apr 2024 4:34pm
