![]() | Home > Photos, Videos & Media > Ed China and his 4.4 TDV8 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Ed China works on his 4.4 tdv8.
He’s got a bad coolant leak too. And possibly the oil cooler too. Anyone else spot it? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 905 ![]() ![]() ![]() |
good to see he is getting things sorted for the MOT test on the 23rd April
A thinly disguised Ebay advert.....
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
yeah saw that...
"Ed you just need to be on this forum mate and you will get all the answers."
If you don't have the security 5 point torx tools to remove the ECU this alows the neccessary access. 2012 TDV8 Vogue (L322) |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 413 ![]() ![]() ![]() |
100% JayGee...I lost interest and turned it off after realising it. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3203 ![]() ![]() ![]() |
I thought it was odd removing the scuttle to change the battery but it saved him moving the ECU and wiring harness out of the way like I did when I changed the battery on ours.
Fantom L322 Member Since: 26 Jul 2024 Location: Melbourne Posts: 2 ![]() ![]() ![]() |
Easy solution just change torx screws to 10mm bolts Justin case you need access when you don’t have all the tools with you |
yes that is what I did, madness to use a torx just to make things more difficult than they have to be ! |
Edd put the L322 in for MOT on 4th June 24, and it failed
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 405 ![]() ![]() ![]() |
Doesn’t make any sense that does it really, I mean why would you put a car in for an MOT with a tyre(s) in such a state. Let alone all the other stuff, which is also bizarre, it’s surely a waste of the £40?
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1815 ![]() ![]() |
Because Ed China is overrated |
