![]() | Home > Wheels & Tyres > New Defender Alloys With 255/60 20s On L322 2012 Westminster |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 614 ![]() ![]() ![]() |
Picked up new set of Defender Alloys with 255/60 x 20 Scorpion Zero All Seasons from Sonearly.
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 215 ![]() ![]() ![]() |
What’s it like in access mode? |
Vertical clearance is fine, drove it around in circles forwards & backward no rubbing at all now. Been bouncing it over speedbumps this afternoon nothing touches,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 ![]() ![]() |
i think it looks good Andy, fills them arches well.. |
Dragonoak4x4 Member Since: 31 Dec 2023 Location: Misson Posts: 8 ![]() ![]() ![]() |
For the front arch I got a bit of 2 x 2 and cut to length, pushed it between the arch liner and the front hub with the wheel off, so the arch liner was forced to beyond where I wanted it to be, then with a heat gun went all around the "gills" area getting it hot, but not melting when I was happy removed the heat and let it cool with the wood in place, I think 10 minutes tops.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4310 ![]() ![]() ![]() |
So, does that mean an L322 wheel will fit a new Defender then?
Not so simple as the ET differs by 15mm. Defender wheel on L322 means the track extends by 15mm on each side so not much of a problem.
Cheers. Excuse my ignorance but what does ET mean?
Not sure, something in French I think. Its the distance between the centre of the wheel rim and the mating face of the wheel to hub vertically in mm
bobsin Member Since: 21 May 2015 Location: wolverhampton Posts: 52 ![]() ![]() |
Disco 5 alloys on my 2004, 9.5" wide, 21" wheels, do fill the arches, with no rubbing....
LukeKnott Member Since: 22 Apr 2024 Location: Warwick Posts: 6 ![]() ![]() ![]() |
I know it's only been a few days, but how has it been living with these so far? I have the opportunity to bag an unused set of 5 for less than it costs a set of tyres normally! |
