Home > Group Buys > wheel centre caps
Page 4 of 4 <1234
RogueRanger
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Thanks @gremlin500. I like the positive thinking… Des
2005 (2006 MY) L322 4.2sc Java Black, 2010 facelift conversion
1965 Lenham Lemans GT 1310 , Gulf Racing blue, FIA spec and road legal
2018 F56 Mini JCW, Thunder Grey/Black, Mulgari St2 tuned, FMIC, short shifter and Eibach springs
Post #686879 1st Mar 2024 11:29am
RogueRanger
GRANGEROVER wrote:
I did it with a suction cup. It just needs to fit and with a quick pull I got them all out.
That’s a good idea. Will see if I have a suction cup small enough…. Des
Post #686883 1st Mar 2024 11:41am
RogueRanger
What was all the fuss about?
I used my smallest trim removal tool and replaced all four wheel centres in about 5 minutes.
Before and after pics for your entertainment.
 Des
Post #688349 18th Mar 2024 3:54pm
Stuart-
Something has come to my attention about the wheel caps I wanted to share for transparency here.
After being out for about a year now, it's become apparent that some are suffering premature wear and tear, in applications where there's a lot of road salt and/or cleaning chemicals used. The metal content in them makes them a bit more vulnerable to these harsh conditions than we initially anticipated and tests suggested.
There are steps we can take to combat this issue and make sure the caps last as long as possible. One option is to apply a protective layer of lacquer before installing them onto your wheels. Another might be a product like Smartwax's "Rim Wax" that is specifically designed to safeguard wheel surfaces from environmental damage.
However, despite this, the savings compared to genuine Range Rover caps (lifespan unknown) are pretty significant. At just £27.95 for a set of 4 with delivery included, ours offer fantastic value. Even if you had to replace them every year, it would still take you 7-8 years to match the price of genuine caps, which will set you back over £200 per set.
So moving forward, lacquer or Rim Wax is recommended before fitment. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1982 Rolls Royce Silver Spirit in green
Spiffing wheel centre caps, L322 sill repair panels, etc
Post #689130 27th Mar 2024 1:10pm
PK17
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Corris Grey
Thanks for such an honest update. I have just ordered another set as a precaution although mine are still perfect.
Post #689139 27th Mar 2024 4:25pm
Page 4 of 4 <1234
