![]() | Home > Technical (L322) > Brake pad falling off |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 490 ![]() ![]() |
Whilst not the perfect example of replacing rear brakes on an L322 (there's very little cleaning taking place and normal grease on the slide pins is a no-no in my view) + I don't like compressing the piston with pliers - a wind-back tool is much better!
Thanks JCW, Original pics were very helpful and you were bang-on with your diagnosis of incorrect discs being fitted! ![]() 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 752 ![]() ![]() |
I know this is stating the obvious but have you checked what has been fitted on the front brakes? |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 188 ![]() ![]() ![]() |
Bodsys brake bible is a very useful bit of reading, lots of tips, torque settings etc.
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 215 ![]() ![]() ![]() |
Is Bodsy's brake bible available in the wiki?
hutchibald Member Since: 13 Nov 2016 Location: Southampton Posts: 2 ![]() ![]() ![]() |
This happened to me too! Pad shot out on a mini roundabout. Non-vented discs had been installed by previous owner. |
Looking at it again I can see how once worn down they can push past the tab grooves into the open space where a vented disk would be and fly off! 2012 TDV8 Vogue (L322) |
Leigh4571 Member Since: 09 Oct 2021 Location: Shropshire Posts: 19 ![]() ![]() |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2566 ![]() ![]() ![]() |
If you haven't yet bought the coolant sensor, check if the float is at the bottom and if it is then a new bottle is required. |
