Home > Technical (L322) > Brake pad falling off
D3Jon
All of your issues are from a combination of the wrong discs as well as the wrong pads. The pads that were fitted are also too small.
Whoever went ahead with the brake replacement, despite the new stuff looking nothing like the old stuff they were taking out should, frankly, be shot, or as a minimum never let near a spanner again! Grrr Evil or Very Mad
Your 2nd picture really shows the issue. The tangs of the pads should sit firmly onto the carrier (ideally on thin replaceable stainless steel bent metal carriers - available as what's called a 'fitting kit' in addition to the discs and pads).
It's clear from the 2nd picture, that as soon as the outer pad was thin enough, it was free to depart through the gap between caliper carrier and disc, and potentially away through some poor sod's windscreen. Oh dear. Shocked
At least you're safe and not too much harm was done (hopefully that is... there's always that flying brake pad!) Smile
J 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #689089 26th Mar 2024 8:43pm
D3Jon
Whilst not the perfect example of replacing rear brakes on an L322 (there's very little cleaning taking place and normal grease on the slide pins is a no-no in my view) + I don't like compressing the piston with pliers - a wind-back tool is much better!
Having said that, check out this quick video to see how the pads should sit into the caliper carrier, making it impossible for them to exit!
2014 Disco 4 HSE
Post #689090 26th Mar 2024 8:54pm
D3Jon
JCW wrote:
Here are the OP’s photos.
I was going to suggest incorrect discs have been fitted, but they’ve obviously been fitted for a good while before this issue has occurred, so perhaps not. The disc not being located centrally between the carrier does look suspicious though.
As others have said, I can’t see how a piston would fall right out even with zero friction material remaining on the pads. Do you mean it pushed beyond the end of the bore or literally fell out?
Thanks JCW,
Original pics were very helpful and you were bang-on with your diagnosis of incorrect discs being fitted! Thumbs Up 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Post #689093 26th Mar 2024 9:29pm
cass
I know this is stating the obvious but have you checked what has been fitted on the front brakes?
Post #689109 27th Mar 2024 9:53am
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Bodsys brake bible is a very useful bit of reading, lots of tips, torque settings etc.
Will
Post #689120 27th Mar 2024 10:47am
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
Is Bodsy's brake bible available in the wiki?
[EDIT] Ahh, I see it is on the disco3 website and specifically for the discovery not the L322/L405 but I suppose some bits might be common.
Post #689122 27th Mar 2024 11:19am
hutchibald
United Kingdom 2006 Range Rover Vogue SE Td6 Buckingham Blue
This happened to me too! Pad shot out on a mini roundabout. Non-vented discs had been installed by previous owner.
Post #689157 27th Mar 2024 6:19pm
JayGee
Looking at it again I can see how once worn down they can push past the tab grooves into the open space where a vented disk would be and fly off! 2012 TDV8 Vogue (L322)
Post #689159 27th Mar 2024 6:35pm
Leigh4571
Hi All,
Thought I would close this thread with the conclusion.
to see where to wrong disks might have been fitted a look in the service history, shows a new rear calliper was fitted by LR main dealer in Wolverhampton.. no flags on the service sheet here. (The PO used main dealer for service & maint. ) this was about 70,000 miles, the car is currently 90,000. the disks are worn clearly been on a while. Could the disks have been changed around 40k miles?
See photos of the disks and new on the bench, it's clear this was the issue.
New disks, OEM Brembo pads (same as original) and new anti rattle clips now fitted.
Something to watch out for.
next job - swap the coolant sensor.
Cheers all, thanks
for the input
Post #689863 4th Apr 2024 7:29am
GraemeS
If you haven't yet bought the coolant sensor, check if the float is at the bottom and if it is then a new bottle is required.
Post #689880 4th Apr 2024 9:22am
