![]() | Home > Technical (L322) > 4.4 SDV8 /TDV8 Engine Failures? |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Quite interesting that you say that. When I had some work done on mine here in France, the ex LR mechanic was saying how nice mine was and that it was the RR to have (because it’s a 4.2). I said I quite the 4.4 TDV8 too but he said he is having loads through his garage with engine failures!
This engine has been in use on L332 and L405 for 14 years now and has a very good reputation for not having a fundamental weakness like many of predecessors. Later owners of older cars may well not have kept up with servicing or on top of inspections due to costs so that will show in more problems. Oil dilution is a problem on any diesel with DPF's so I don't see why this engine should be any different. If you are a RR owner in France finding any mechanic with a good knowledge of these cars to properly maintain them is difficult so it's likley the effects of neglect is even greater there. Nothing 'shocking' to see IMO unless someone can point to a specific and common failure issue like the V6 crank or 3.6 Turbo/EGR. 2012 TDV8 Vogue (L322) |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
D3Jon, nothing specific to the engine, just poor/inadequate maintenance.
RogueRanger Member Since: 03 Jan 2024 Location: Kent Posts: 116 ![]() ![]() ![]() |
This. And it also applies to the reputation of RRs in general. Des 2005 (2006 MY) L322 4.2sc Java Black, 2010 facelift conversion 1965 Lenham Lemans GT 1310 , Gulf Racing blue, FIA spec and road legal 2018 F56 Mini JCW, Thunder Grey/Black, Mulgari St2 tuned, FMIC, short shifter and Eibach springs |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3812 ![]() ![]() ![]() |
I note the point, “Not replacing the EGT sensor “etc.
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 513 ![]() ![]() |
Have removed the word "Shocking" from the title! I've watched too many YouTube video's where they add words like that to the video clip title to grab attention! ![]() Thanks for all the replies so far guys ![]() It's just when you see Camtechcraig (who we all respect and know is very knowledgable) needing an engine for his missus's L405, then see posts about another 4.4 TDV8 lunching itself, and another with a snapped timing chain, it started to make me worry a tad! I saw a lovely looking L405 AB on Autotrader, private sale in Central London - which put me off it altogether. This might be unfair, but I'm assuming the vehicle has done a lot of city stop/start driving and loads of idling. I might be totally wrong, and it was only used for long runs to a second home in the Cotswolds, but I just took it off my list of potential vehicles straight away! Keep the posts coming please, I'm particularly interested to hear from people who've had a big problem with this engine and understand what the vehicle's previous driving cycle had been? Cheers, Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8518 ![]() ![]() ![]() |
No scientific reason, just a hunch....
It agrees with what my local independent thinks, he talked me out of buying a 2019 4.4 because of the numbers failing and the difficulty getting spares.
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 289 ![]() ![]() ![]() |
I think an important consideration is what if it does fail, as LR can no longer supply short block or full engines, so it does somewhat limit you're options.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1310 ![]() ![]() |
OK here's my 2 cents worth!
Mine was getting oil changes under 6k miles and well before reaching 7% dilution and it still went bang.
What part of the internals failed? 2012 TDV8 Vogue (L322) |
Spun no.3 cylinder big end bearings, see here;-
Wow - amazing rebuild job. What do you think was the primary cause of the spun bearing? 2012 TDV8 Vogue (L322) |
