Home > Technical (L322) > 4.4 SDV8 /TDV8 Engine Failures?
Page 1 of 4 1234>
D3Jon
I've always been of the understanding and personal belief that the 4.4 TDV8 / SDV8 is a very strong, reliable engine.
Yes, the 4.4 TDV8 has a couple of minor issues with oil cooler gasket failures, alternator failures and turbo drain mods being required - but nothing that would be classed as catastrophic, such as the well known TDV6 / SDV6 crank snapping issue so well promoted by that nice German couple on Youtube.
My previous (now sold) 2011 L322 4.4 TDV8 gave me impeccable service with no major issues whatsoever to 122K miles when I sold it. It never even had the oil cooler issue, the only engine issue was the aux belt tensioner became noisy (another well known minor irritation).
However, I've now seen at least three fairly recent posts on this forum discussing catastrophic engine failures affecting the 4.4 diesel V8 engine.
What is the collective wisdom of this forum as to the cause of these issues please? The only thing I can think of, would be related to premature engine wear (big ends, etc) from oil dilution caused by multiple incomplete Active DPF regens. So in effect, primarily affecting cars that have done frequent short journeys or are 'city cars'.
I'm on the lookout for a L405 4.4 TDV8 and interested to understand what is thought to be at the root of the 4.4 TD/SDV8 engine failures?
TIA,
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #689096 26th Mar 2024 11:51pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Quite interesting that you say that. When I had some work done on mine here in France, the ex LR mechanic was saying how nice mine was and that it was the RR to have (because it’s a 4.2). I said I quite the 4.4 TDV8 too but he said he is having loads through his garage with engine failures!
I was in a rush so never thought to ask what was up with them, but he said he wouldn’t have one.
Surprised me me as I thought they were very robust.
Post #689099 27th Mar 2024 6:37am
JayGee
This engine has been in use on L332 and L405 for 14 years now and has a very good reputation for not having a fundamental weakness like many of predecessors. Later owners of older cars may well not have kept up with servicing or on top of inspections due to costs so that will show in more problems. Oil dilution is a problem on any diesel with DPF's so I don't see why this engine should be any different. If you are a RR owner in France finding any mechanic with a good knowledge of these cars to properly maintain them is difficult so it's likley the effects of neglect is even greater there. Nothing 'shocking' to see IMO unless someone can point to a specific and common failure issue like the V6 crank or 3.6 Turbo/EGR. 2012 TDV8 Vogue (L322)
Post #689100 27th Mar 2024 7:11am
garyRR
D3Jon, nothing specific to the engine, just poor/inadequate maintenance.
As the miles creep up, oil changes become ever more important. Every 7,000 miles seems the point forum members change the oil.
Too infrequently, especially short trips increase oil dilution and number of heat cycles the engine and oil have endured.
Oil cooler o-rings left too long without repair will reduce the oil level and coolant level, potentially causing premature wear.
Not fixing intake leaks will cause the engine to consistently overboost, increasing wear. Additionally, it is a guaranteed route to DPF problems.
Not replacing a failed EGT sensor will eventually show itself, as the car ECU instead uses a default value.
The only differences I've read between the 4.4 TDV8 and SDV8 that could make a difference are that the TDV8 had the turbo smoke screen (issue fixed on the SDV8) and there are instances of the HPFP failing on the SDV8 but not the TDV8.
The old adages of looking for a car with good history and evidence of regular oil changes apply. Personally, I'd also not look for one with too low miles, because this will be a massive tell-tale it's been used for lots of short trips. It can instead pay to save both the money on one with higher miles, as well as dependability. c,10,000 per year are the right ones to be looking at. E.g. if 2015, go for one around 90,000 miles or more. 2015 Range Rover Autobiography 4.4 SDV8
Post #689102 27th Mar 2024 7:47am
RogueRanger
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
This. And it also applies to the reputation of RRs in general. Des
2005 (2006 MY) L322 4.2sc Java Black, 2010 facelift conversion
1965 Lenham Lemans GT 1310 , Gulf Racing blue, FIA spec and road legal
2018 F56 Mini JCW, Thunder Grey/Black, Mulgari St2 tuned, FMIC, short shifter and Eibach springs
Post #689104 27th Mar 2024 8:54am
Baltic Blue
I note the point, “Not replacing the EGT sensor “etc.
Six monthly or 6k miles MAX oil changes to keep the oil fuel contamination figure below 5 or 6 is the only sensible route to prolong engine life.
Post #689105 27th Mar 2024 9:28am
D3Jon
JayGee wrote:
<SNIP> Nothing 'shocking' to see IMO unless someone can point to a specific and common failure issue like the V6 crank or 3.6 Turbo/EGR.
Have removed the word "Shocking" from the title! I've watched too many YouTube video's where they add words like that to the video clip title to grab attention! Embarassed
Thanks for all the replies so far guys Thumbs Up It confirms what I thought, that this engine is one of the best out there (and in no way shocking)!
It's just when you see Camtechcraig (who we all respect and know is very knowledgable) needing an engine for his missus's L405, then see posts about another 4.4 TDV8 lunching itself, and another with a snapped timing chain, it started to make me worry a tad!
I saw a lovely looking L405 AB on Autotrader, private sale in Central London - which put me off it altogether. This might be unfair, but I'm assuming the vehicle has done a lot of city stop/start driving and loads of idling. I might be totally wrong, and it was only used for long runs to a second home in the Cotswolds, but I just took it off my list of potential vehicles straight away!
Keep the posts coming please, I'm particularly interested to hear from people who've had a big problem with this engine and understand what the vehicle's previous driving cycle had been?
Cheers,
2014 Disco 4 HSE
Post #689106 27th Mar 2024 9:29am
No scientific reason, just a hunch....
It "seems" to me that it's the slightly later 405's with addblue that fail
I've not heard of earlier 405's or 322's running bearings etc...
Just my 2p... I maybe well off... Thumbs Up Pete
Post #689116 27th Mar 2024 10:24am
Baltic Blue
It agrees with what my local independent thinks, he talked me out of buying a 2019 4.4 because of the numbers failing and the difficulty getting spares.
Cheers
Post #689133 27th Mar 2024 2:20pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
I think an important consideration is what if it does fail, as LR can no longer supply short block or full engines, so it does somewhat limit you're options.
If you're lucky and it has a LR warranty and impeccable service history it's a buy back from LR, if not its a rebuild (as I did), recon engine or a secondhand unit, all of which are wallet draining. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #689134 27th Mar 2024 3:33pm
Kot
OK here's my 2 cents worth!
Without doubt its fuel dilution, I go by the service indicator in the Incontrol app and see immediately after a Regeneration has taken place (yes I am sad I monitor them Rolling with laughter ), I can see how much the miles to the next service has reduced. Lucky to get between 2k to 3k miles before I change the oil. I do usually, 3 or 4 changes a year. But I am rural and lots of short journeys so worst case. My average mileage to next Regeneration is around the 100 mile mark!
Imagine Joe Public who is adamant that it gets 1 service a year or at 16k miles (as advertised) and ignores the IC app or doesn't see/ignores the message on the dash. Not prepared to pay for more services and not prepared to do them himself either.
@Haylands you have a point! as the later models have slightly different DPF/Exhaust Architecture which contributes in failed Regens contributing more to increase fuel dilution.
To cap it all, JLR were so Censored by customers claiming the service light was coming on prematurely they offered a software update to increase the 7% dilution limit which is high anyway to 10%!!!!
For me its a ticking bomb watch this space Whistle 2018 SE SDV8 4.4 Byron Blue
Post #689141 27th Mar 2024 4:44pm
4RRS
Mine was getting oil changes under 6k miles and well before reaching 7% dilution and it still went bang.
Interestingly when the engine was pulled apart it was showing just over 3% dilution via my IID tool, however an oil analysis report from Millers oils, showed true oil dilution at .58%. Had all injectors tested during the rebuild and all good, so never got to the bottom of why it failed. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #689145 27th Mar 2024 5:06pm
JayGee
What part of the internals failed? 2012 TDV8 Vogue (L322)
Post #689150 27th Mar 2024 5:40pm
4RRS
Spun no.3 cylinder big end bearings, see here;-
https://www.fullfatrr.com/forum/topic68615.html L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #689154 27th Mar 2024 6:01pm
JayGee
Wow - amazing rebuild job. What do you think was the primary cause of the spun bearing? 2012 TDV8 Vogue (L322)
Post #689156 27th Mar 2024 6:11pm
Page 1 of 4 1234>
