Home > In Car Electronics (L322) > L322 Head Unit - Decent SAT NAV
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi, I realise the subject of head units for 2010-2012 L322s has been done to death but my request is simple, I don't need Apple car play, Google, data or any of that stuff, I just want a decent Sat Nav.
I'm using a tablet right now but it's a bit aftermarket and detracts from the interior so is there anything I can do to the standard head unit to be able to support Sygic, or other up to date Sat Navs ?
I'm guessing not, as spending an age going through all the topics in the forum I can find the only one I can see to retain the original head unit is still very pricy.
Do you guys know if there's anything on the market now that can do the above that doesn't cost the earth and retains the original appearance ?
Cheers
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #688581 21st Mar 2024 11:03am
your existing head unit has a very inaccessible hard drive for the sat nav....theres no way of introducing another navigation software..
the only alternative is adding hardware that gives you carplay/android auto... ... - .- -.
Post #688595 21st Mar 2024 12:33pm
AndyRoo
Hi Stan, many thanks, I suspected as much.
Is there anyone on the forum selling that internal modification solution or the replacement full screen, or could do it for me do you know ?
Although I can do myself, I'd rather someone who's familiar with it do do for me as I'm not really looking forwards to ripping the dash out.
Post #688604 21st Mar 2024 2:17pm
have a word with garyrr, he seems to be in the know,
https://www.fullfatrr.com/forum/topic69334.html ... - .- -.
Post #688608 21st Mar 2024 2:24pm
AndyRoo
Cheers Stan I'll PM him
Post #688611 21st Mar 2024 2:51pm
garyRR
AndyRoo, there's only 3 options.
1. Additional CarPlay screen stuck on top of the dash (which from your post is not what you want)
2. Replacement screen with wireless Android Auto and wireless CarPlay and also built in Maps, Spotify etc (runs Android, so you can download any apps)
3. Navitech CarPlay system - integrates with the old screen. In my own personal opinion, the old screen is too small and too low quality vs the cost of this system to make it worthwhile
Here's the L322 with a replacement screen:
 2015 Range Rover Autobiography 4.4 SDV8
Post #688766 23rd Mar 2024 9:34am
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
how with clock / date settings and controling front/rear speakers and Logic7 settings?
Post #688771 23rd Mar 2024 10:23am
garyRR
Date and time is managed through the screen, it has a Canbus reader.
There's an in-built equaliser which actually improves the sound from the Logic 7 system, better than the sound quality from the stock LR system. 2015 Range Rover Autobiography 4.4 SDV8
Post #688772 23rd Mar 2024 10:27am
AndyRoo
I'm not sure if it makes any difference to the head unit but I have the HD audio system that I want to retain as is.
I'll have to park for now as just forked out for a new set of wheels and some paintwork, SHMBO will go bananas if I drop that in as well.
But many thanks for the info though, will quietly brood over it for a while.
Post #688774 23rd Mar 2024 11:27am
jimmie
fader and balance works? How with hands free quality?
Post #688854 24th Mar 2024 10:35am
AndyRoo
Hi,
I'm now wanting to upgrade the media screen to an Android one, I personally think the 10.25" unit seems a neater fit than the 12.5" but I'm not really that bothered if the quality is there on the bigger screen.
Three questions I have if I may, what is the best version of either size for 2012 car, there appear to be many options on Ali Express ?
Secondly, The larger screen, how does it look from the side, it appears to sit proud of the dash, so is it leaving an unsightly/ tacky surround when viewed from the side / 3/4 view ?
Thirdly, will they support the HD audio system, i.e. 13 speaker + woofer ?
It's expensive so I want to be sure on the model before I take the plunge.
Cheers.
Post #708048 1st Jan 2025 10:19pm
Steveg
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
Here’s the 10.25” one I fitted…
Link here…
https://www.aliexpress.com/item/1005004301...f19cw2HOIq
Post #708050 1st Jan 2025 10:43pm
AndyRoo
Thanks for that, it does look a neat install.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #708051 1st Jan 2025 10:49pm
Steveg
It might be particular to my RR, but I found that I had electrical and white noise after install, so I’d recommend fitting some filters just in case you have the same. It will save having to pull the dash apart again 😊
Post #708069 2nd Jan 2025 9:28am
AndyRoo
Hi, good tip, I'll order some and also change the blower assy at the same time.
Cheers
Post #708141 2nd Jan 2025 9:06pm
