Home > Maintenance & Mods (L322) > wind noise
Rangeymad
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Galway Green
wind noise
Sound deadening .I'm on my 5th L32 and wondered if you guys could help.
I'm pretty sure that there was a solid block of foam when you opened the bonnet close to the windscreen and door which I guess was there to stop wind noise. There is certainly a residue of glue and foam you can see where it would have been. Can anyone tell me if there is a part number so I can order a replacement.
Compared to battery drain, air suspension, gear box faults this probably sounds an anal request but my 2011. 4.4 Vogue SE is definitely a keeper and my pride and joy so if you can help this "anorak" I would be grateful.
Post #688422 19th Mar 2024 4:51pm
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
I can't help you with part numbers I'm afraid, but my foam blocks went the way of many and turned into soggy rust trap sponges so I removed them. no discernible difference in wind noise whatsoever. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #688424 19th Mar 2024 5:03pm
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
If you search the forum you will find a post about this. The general consensus was that the Foam did not help with wind noise but someone had the part numbers up there. I was searching the same thing as I had annoying noise, most of which is the rubber seal on the window and tyres.
Those foam blocks were quite expensive. For me priority is quieter tyres before the years is out. Current yokes
2012 4.4 TDV8 Westminster
Subaru Sambar Pickup Tipper
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #688428 19th Mar 2024 5:27pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
There was a discussion here with part pictures :
https://www.fullfatrr.com/forum/topic65834.html
Mixed opinions as to what they were for but they are still in place on mine and in good condition. TDV8 4.4 2012
Post #688429 19th Mar 2024 5:29pm
Rangeymad
Many thanks I am amazed at how helpful the folks on this site are. Its basically a trivial matter but important to an anal 322 owner like me.
Post #688578 21st Mar 2024 10:42am
