Home > Maintenance & Mods (L322) > wind noise |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 544 |
I can't help you with part numbers I'm afraid, but my foam blocks went the way of many and turned into soggy rust trap sponges so I removed them. no discernible difference in wind noise whatsoever. Drives:
19th Mar 2024 4:03pm |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 189 |
If you search the forum you will find a post about this. The general consensus was that the Foam did not help with wind noise but someone had the part numbers up there. I was searching the same thing as I had annoying noise, most of which is the rubber seal on the window and tyres.
19th Mar 2024 4:27pm |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 281 |
There was a discussion here with part pictures :
19th Mar 2024 4:29pm |
Rangeymad Member Since: 22 Sep 2022 Location: suffolk Posts: 7 |
Many thanks I am amazed at how helpful the folks on this site are. Its basically a trivial matter but important to an anal 322 owner like me. |
21st Mar 2024 9:42am |
