Home > Maintenance & Mods (L322) > aux belt and tensioners 4.4TDV8 what parts
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
Hi guys
I've tried searching different phrases on the site and I am getting getting a lot of results so I'm hoping someone who has done this job can just clear this up for me.
I'm getting squeaky belt noises. I've been trying to search for a Kit but it seems these parts are sold individually. What exactly am I replacing when I go to do this job:
https://www.advancedfactors.co.uk/auxiliar...1791-c.asp
There are 7 part numbers listed in the above and noticed from most peoples posts they just replace the tensioner and belt but should all these parts be replaced if you are in there?
I will also try to do the starter motor and water pump as I believe if you are in that deep you might as well as my car is 2012 with 214km on it. Current yokes
2012 4.4 TDV8 Westminster
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #688395 19th Mar 2024 11:06am
PeteT80
I did both belts, tensioner, all the pulleys/idlers and water pump. Dayco belts and genuine LR parts for the rest. Also replaced alternator, genuine Denso.
Post #688396 19th Mar 2024 11:16am
D3Jon
When I did my 2011 TDV8 (now sold) a few years ago, I only replaced the belt and tensioner. But that was at around 80K miles due to a noisy tensioner (housing had starting to crack which is / was a common problem). The car was also only around 6 yrs old at that time. I understand the newer tensioners are better and less prone to cracking.
Once the fan & belt was off, I checked all the other pulleys and everything span freely, without any play and without any noises at all (otherwise I would have changed them as well).
You have a few more miles (km's?) on your vehicle, it's also getting on for 12 years old now, so it wouldn't be a bad idea to change all the pulleys as you suggest. As you say, you might as well do the alternator whilst you're in there, and water pump for good measure - especially if you're planning on keeping the vehicle!
Not sure if there's a specific kit for this, I'd give Advanced Factors a ring, see if they can do you a good deal on the whole lot! Thumbs Up 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #688397 19th Mar 2024 11:21am
Fla
Hi guys
Thanks for that valuable info. I was hoping to get a full kit from the likes of Dayco with all pulleys, belts and bolts but it doesn't seem to exist. I have found the Denso alternator at a reasonable price €250 and the water pump isnt bad either.
I have tried advanced factor for a one or two bits and they are great to respond to emails and help but their carriage to Ireland is too high. They needed €50 for 2 sensors and 2 brake splash plates. Not their fault, carriage to the UK has always been cheap from Ireland but from the UK to Ireland has always been expensive. Current yokes
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #688398 19th Mar 2024 11:52am
ballast
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Just done it on my 3.6 TDV8 due to squeaking and discovered it's the power steering pump... Crying or Very sad
Not a bad job on the 3.6, getting the belt back on was a bit of a pig mind.
Post #688400 19th Mar 2024 12:03pm
PeteT80
I use Maltings 4x4 for all my parts, reasonable prices for genuine parts. Always helpful and next day delivery.
Post #688404 19th Mar 2024 12:17pm
Fla
Thanks Pete but unfortunately none of the UK suppliers are good value for us in Ireland now due to brexit and carriage charges. Its often far cheaper for me to go to a main dealer here and order from them but the delays in getting parts due to JLR warehouse issues can be frustrating.
I think Ill price up genuine rollers like you say and get the Dayco belts and tensioner then Current yokes
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #688418 19th Mar 2024 3:19pm
JayGee
Why not order from Autodoc in the EU? 2012 TDV8 Vogue (L322)
Post #688460 19th Mar 2024 8:39pm
