Home > Maintenance & Mods (L322) > Squealy brakes after removing calliper counterweights
ByronBlay
Australia 2008 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Hi
I recently replaced the stock 20 inch low profile wheels on my range rover sport 2008 L320 V8 supercharged with a beautiful set of black MO1882 18 inch compomotive wheels as I cracked a low profile rim on the rough roads where I live (tropical hinterland near Byron Bay NSW Australia).
The MO1882 wheels are fantastic, but to fit the wheels I had to remove the brake calliper counterweights as the space is so tight and the calipers huge on the supercharged.
Now the front brakes squeal terribly when slowly braking to stop in traffic in town, intersections, pedestrian crossings, parking etc. No Problem slowing from higher speeds.
Obviously the counter weights are there to prevent this (which is annoying) but not enough room to put them back.
Have you heard of this problem before?
Is there a solution?
Not an option to go back to the stock wheels...
Post #688018 13th Mar 2024 8:25pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
You could try copper grease on all the metal to metal contact surfaced and the pad backs.
It's a long shot but removing direct metal to metal contact should minimise the squeal, I can't prve that it will, it just feels right.
Worth a try for the price of a tube of grease
Andy Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #688040 13th Mar 2024 10:53pm
JayGee
Try asking this in the L320 forum. Copper grease should not be anywhere near a modern brake system although Ceramic grease may have specific uses. 2012 TDV8 Vogue (L322)
Post #688056 14th Mar 2024 10:24am
AndyRoo
Hi, I stand corrected, every day is a school day.
I'll have to get myself some ceramic paste for brakes now.
Post #688057 14th Mar 2024 10:38am
Shaunj69
England 2012 Range Rover Autobiography 4.4 V8 Zambezi Silver
Re: Squealy brakes after removing calliper counterweights
ByronBlay wrote:
Hi
The counterweights are for noise reduction/vibration. And yes please do not put cooper grease any ware near the braking system. L322 TDV8 2011 Autobiography
Working for an OE aftermarket car parts suppler
Post #688060 14th Mar 2024 11:27am
Marcus76
2006 Range Rover HSE 4.4 V8 Alaska White
Hello,
Excuse my bad English, What is a counterweight on the brake? Ist it called “ Antiquitschblech“ in Germany? My car does the same but I had nothing removed from the brakes. Is it possible to post a picture of the counterweights?
Is there any other reason for that sound of an old train breaking?
Marcus
Post #688062 14th Mar 2024 11:45am
Shaun_
Excuse my ignorance, but what do you count as a 'modern' braking system, and what is the issue with using copper grease on them?
Thanks
Shaun 2012 TDV8 Westminster in the New Forest
Also: Land Rover Series 3 SWB, Mercedes 280SL, Classic Mini race replica, VW Golf SV
Previously: Audi A8, RR TDV8 Vogue, Audi Allroad, VW Golf GTI Edition 30, Audi A4 Avant, A8, A4 Sport, A6, VW Golf Mk5, Bora, Golf GTI Mk3, Jetta Mk3, Passat, Jetta Mk1, Golf Mk1
Post #688083 14th Mar 2024 3:03pm
Marcus76
Hello,
My workshop tells me : dust sticks on the copper Paste an it could not stand as high temperatures as the ceramic paste. It was ok in the past, but not nowadays. Since they told me that and i saw the dirt and dust sticking on the copper paste i only use ceramic paste. The dust and dirt together with the copper paste is really hard and sticky. And again excuse my bad english.
Marcus
Post #688085 14th Mar 2024 3:20pm
Copper grease should not be used on aluminium as it will set up electrolysis and corrode the aluminium, it is OK if you have steel callipers but shouldn't be anywhere near aluminium.
There are better modern alternatives for aluminium and steel though...
Years ago it was common to drill a 10mm hole in the middle of the pads, doesn't effect braking but sure helps with slow speed squealing... drill from the pad side to prevent blow out of the pad material.... Pete
Post #688087 14th Mar 2024 3:24pm
Shaun_
That's very interesting and good to know - thanks.
Thumbs Up 2012 TDV8 Westminster in the New Forest
Post #688089 14th Mar 2024 3:27pm
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
I have been given conflicting opinions stating that it should no longer be necessary to grease the backs of the pads anymore? But surely that would depend on the quality of the pad in question. Also is using something like Ceratec more suitable to use for both the pads and retaining pins to help prevent the retaining pins from seizing in the calliper or do you still use copper grease for the pins/bolts?
Post #688095 14th Mar 2024 5:14pm
kevinp
I use this.
Post #688097 14th Mar 2024 5:24pm
JayGee
The issue with any form of grease these days is that the common use of pressure washers which are very good at removing built up brake dust on calipers can dislodge it and move it onto the friction surfaces. The only place for grease is on encapsulated sliding pins and then it's important to use the right amount and the right type. 2012 TDV8 Vogue (L322)
Post #688126 15th Mar 2024 9:29am
Shaunj69
Hi ReggieMac
New modern brake pads don't need grease on the back plate of the pad or the piston of the caliper.
They now come with noise reducing shims, A lot of RandD goes into brakes now a day to stop NVH. If you apply grease on the back of the pads the shim cant do its job. The only place "Brake grease" is to be used is on the abutment point of the pad. Copper grease is not suitable for the brake environment as it is very susceptible to an electrochemical reaction known as galvanic corrosion when it comes into contact with a dissimilar metal in the presence of an electrolyte, even salty water will do. The example of this reaction is most commonly seen as the white chalky powder on the back of the alloy wheels. Copper Grease has poor lubricating properties. It is in fact an anti-seize compound.
Why not grease on the caliper piston? Grease is oil based and will degrade any rubber it comes into contact with ie Caliaper piston dust cover and piston seals.
Hope this help L322 TDV8 2011 Autobiography
Post #688127 15th Mar 2024 9:32am
JayGee
There is specific piston seal grease that won't react with the rubber or more importantly the brake fluid. 2012 TDV8 Vogue (L322)
Post #688131 15th Mar 2024 10:04am
