Home > Technical (L322) > Can't get into the car |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 187 |
It doesn't have a couple of those stick on after market covers on them does it? I see a lot of people selling them. I would think it highly unusual that a RR wouldnt have key access.
7th Mar 2024 6:52pm |
I assume you have the emergency key blade in your fob? You prob read the below…..
Redtail Member Since: 10 May 2018 Location: Maidenhead Posts: 20 |
Yes, unfortunately there is no hole under the covers, not even a lock symbol on the face of them.
7th Mar 2024 7:16pm |
What colour are your door handles? Black? Maybe got covers on as mentioned above?
7th Mar 2024 7:28pm |
You might be right about after market. The top covers, black, are attached with thin foam tape, but there still isn't a prise hole underneath. I'm reluctant to break off the under covers if there isn't anything underneath. 2010 5.0SC. It's never had a tow bar fitted. Thx Roy |
7th Mar 2024 7:34pm |
Hi Redtail
8th Mar 2024 7:27am |
Thanks people.
8th Mar 2024 11:54am |
Great news!
8th Mar 2024 11:58am |
That’s good then. I know some folk have hid a battery connector somewhere that you can get to and connect a charger to. I have tow electrics so I can use that. Some have fitted solar chargers but you have to make sure the Aux sockets stay live when the car goes to sleep. Early cars did but later ones didn’t…..
8th Mar 2024 12:17pm |
mjdronfield
8th Mar 2024 12:30pm |
I believe so, you just need the positive and negative feeds that go to the battery. I’m not a towing electrics expert but I can’t see why you couldn’t fit a towing 13 pin or is it a 7 pin? socket to your car even if you don’t have an actual tow bar. If you have tow electrics already you can make up a socket to connect to the correct pins and goes to a trickle charger. You used to be able to buy one from the site shop, on the Disco 3 bit, but I don’t think they are available now for some reason. I have a CTEK charger that I connect to via this method.
8th Mar 2024 1:10pm |
Wiltshire130 Member Since: 05 Aug 2023 Location: Wiltshire Posts: 22 |
This is my system.
8th Mar 2024 1:47pm |
