![]() | Home > Technical (L322) > Can't get into the car |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 189 ![]() ![]() ![]() |
It doesn't have a couple of those stick on after market covers on them does it? I see a lot of people selling them. I would think it highly unusual that a RR wouldnt have key access.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7894 ![]() ![]() ![]() |
I assume you have the emergency key blade in your fob? You prob read the below…..
Previous cars : 2003 Range Rover Vogue TD6 1999 Discovery Td5 ES 1995 BMW M5 3.8 6 speed 1992 Range Rover 3.9 Efi Vogue 1992 BMW M5 3.8 1988 BMW 735i SE 1989 Ford Sierra XR4x4 2.9i 1981 Ford Fiesta Supersport |
Redtail Member Since: 10 May 2018 Location: Maidenhead Posts: 20 ![]() ![]() ![]() |
Yes, unfortunately there is no hole under the covers, not even a lock symbol on the face of them.
What colour are your door handles? Black? Maybe got covers on as mentioned above?
You might be right about after market. The top covers, black, are attached with thin foam tape, but there still isn't a prise hole underneath. I'm reluctant to break off the under covers if there isn't anything underneath. 2010 5.0SC. It's never had a tow bar fitted. Thx Roy |
Hi Redtail
Thanks people.
Great news!
That’s good then. I know some folk have hid a battery connector somewhere that you can get to and connect a charger to. I have tow electrics so I can use that. Some have fitted solar chargers but you have to make sure the Aux sockets stay live when the car goes to sleep. Early cars did but later ones didn’t…..
mjdronfield
I believe so, you just need the positive and negative feeds that go to the battery. I’m not a towing electrics expert but I can’t see why you couldn’t fit a towing 13 pin or is it a 7 pin? socket to your car even if you don’t have an actual tow bar. If you have tow electrics already you can make up a socket to connect to the correct pins and goes to a trickle charger. You used to be able to buy one from the site shop, on the Disco 3 bit, but I don’t think they are available now for some reason. I have a CTEK charger that I connect to via this method.
Wiltshire130 Member Since: 05 Aug 2023 Location: Wiltshire Posts: 27 ![]() ![]() ![]() |
This is my system.
Ignore the heavy yellow cable - charging the EV as finally we have some sun. |
