![]() | Home > Technical (L322) > Fluid leak around the passenger front wheel (power steering) |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 780 ![]() ![]() ![]() |
Check for a split in that CV joint boot. The older I get, the more I realise that people confuse wrinkles for wisdom |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 450 ![]() ![]() ![]() |
Thanks. Will do. Seems quite a burst of oil, some still very slightly dripping from the plastic shroud.
It may not be the boot, but I had one split once on my old Vogue and it looked like Ron Jeremy had been spaffing black stuff in there for weeks!! |
Sounds about right. I’m no mechanic - is it something like transmission fluid that is leaking from the split boot (if it is that). No idea of what the CV joint entails.
It's just grease, but friction temperature makes it like sticky WD40! The older I get, the more I realise that people confuse wrinkles for wisdom |
Turns out it’s a power steering fluid leak.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
RAC mean beat me to it!
That was going to be my next guess after the CV boot....... |
Thanks. Good advice.
What’s the best website for exploded diagrams for L322’s?
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 195 ![]() ![]() ![]() |
The workshop manual in the WIKI has a clear diagram with all the components, section 211-02, steering system. It also has all the torque values etc.
Brilliant thanks. 2009 pre-facelift 3.6 TDV8. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3201 ![]() ![]() ![]() |
Land Rover have their own Classic Parts website with diagrams, part numbers and prices which is fantastic.
Cool thanks. 2009 pre-facelift 3.6 TDV8. |
