Home > Technical (L322) > Fluid leak around the passenger front wheel (power steering)
KitTheRam
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
Spotted an oil leak (circled in red below) after a 30min drive today.
Only thing that I remember was hearing an odd ticking noise while at the traffic lights after setting off.
Drives fine, sits normal and no warnings lights.
Just what looks like a small explosion of light oil at a low’ish point of the wheel well (engine bay is dry).
Have a look, any advice welcome!
 2009 pre-facelift 3.6 TDV8.
Post #687080 3rd Mar 2024 7:46pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Check for a split in that CV joint boot. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #687081 3rd Mar 2024 7:52pm
KitTheRam
Thanks. Will do. Seems quite a burst of oil, some still very slightly dripping from the plastic shroud.
Hence the cardboard box. 2009 pre-facelift 3.6 TDV8.
Post #687086 3rd Mar 2024 8:24pm
JMC
It may not be the boot, but I had one split once on my old Vogue and it looked like Ron Jeremy had been spaffing black stuff in there for weeks!! Rolling with laughter The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #687094 3rd Mar 2024 9:20pm
KitTheRam
Sounds about right. I’m no mechanic - is it something like transmission fluid that is leaking from the split boot (if it is that). No idea of what the CV joint entails.
Would the oil drip from the plastic under-tray like mine is if it’s the CV joint? (See red circles on the pics above) 2009 pre-facelift 3.6 TDV8.
Post #687100 3rd Mar 2024 10:34pm
JMC
It's just grease, but friction temperature makes it like sticky WD40! The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #687103 3rd Mar 2024 11:01pm
KitTheRam
Turns out it’s a power steering fluid leak.
Weeping from a metal hose / pipe somewhere behind the bumper according to the nice RAC bloke who came out to investigate.
Guessing it squirted out everywhere while I was near to full lock at some point on my way home the other day.
Need to top it up to get to my mates garage, what’s the best stuff? Texaco Cold Climate 33270?
Guessing this - https://www.ebay.co.uk/itm/156080068807?mk...media=COPY
Or will this do… https://www.ebay.co.uk/itm/112135504332?mk...media=COPY 2009 pre-facelift 3.6 TDV8.
Post #687370 6th Mar 2024 9:27pm
garyRR
RAC mean beat me to it!
My immediate thoughts were your high pressure power steering hose. The reason - because there's clearly a spray mark on the arch.
They're not too difficult to change - only thing is the position of the power steering pump.
Power steering fluid grade is EXT but the handbook states "Texaco Cold Climate PAS Fluid 14315 (UK)" Just be mindful that as your hose has let go, air is making its way into the system, so irrespective of topping up, you risk damage to your pump. 2015 Range Rover Autobiography 4.4 SDV8
Post #687421 7th Mar 2024 4:07am
JMC
That was going to be my next guess after the CV boot....... Whistle The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #687425 7th Mar 2024 9:00am
KitTheRam
Thanks. Good advice.
It will only be driven to my mates garage locally.
But for now it will sit weeping tiny bits of oil on a piece of cardboard on my drive! 2009 pre-facelift 3.6 TDV8.
Post #687498 7th Mar 2024 11:29pm
KitTheRam
What’s the best website for exploded diagrams for L322’s?
Trying to get a sense of where these pipes are located! 2009 pre-facelift 3.6 TDV8.
Post #687668 10th Mar 2024 10:01am
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
The workshop manual in the WIKI has a clear diagram with all the components, section 211-02, steering system. It also has all the torque values etc.
Will
Post #687714 10th Mar 2024 7:02pm
KitTheRam
Brilliant thanks. 2009 pre-facelift 3.6 TDV8.
Post #687716 10th Mar 2024 7:29pm
dhallworth
Land Rover have their own Classic Parts website with diagrams, part numbers and prices which is fantastic.
https://parts.jaguarlandroverclassic.com/?...bcQAvD_BwE 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #687730 10th Mar 2024 10:03pm
KitTheRam
Cool thanks. 2009 pre-facelift 3.6 TDV8.
Post #687733 10th Mar 2024 10:27pm
