Home > Maintenance & Mods (L405) > High Performance or Standard Brakes, how can I tell?
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
I have tried searching the forum and am still a bit stumped, in fact I am getting so confused just trying to find the correct parts that I need to order to do a full disc, pad, fitting kit and wear sensor replacement on my RR.
I see so many different parts and different part numbers and just when I think I may have sussed it out I get stumped with yet another option of 'Performance or Standard' brakes, how can I tell?
I have a 2019 FFRR Autobiography 4.4 Diesel. My front callipers are grey and have the 'Range Rover' logo stamped on them (no mention of Brembo so I am guessing that version I can ignore?).
Without actually taking the wheels off and taking photos, measurements and trying to match things up is there an easy way to tell if they are 'Performance' or 'Standard'?
Apologies if I am over thinking this but this will be my first bit of DIY on a vehicle I own for many, many years and slowly getting back into doing the basic things so want to get this right first time. Thumbs Up
Post #686979 2nd Mar 2024 6:08pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
Post a picture through the wheel. I believe they are the six piston front calipers. We don’t have the 4.4SDV8 in 🇨🇦.
The RR doesn’t have Brembo on them, but they are Brembo. The RRS sometimes has Brembo on them. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #686984 2nd Mar 2024 6:37pm
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
Hello,
I think you will have the same callipers as I do. I had an issue with finding the correct pin and spring kit. It seems that some sites don't list the newer part numbers - listing the older part numbers as correct.
I have posted photos and part numbers in this thread:
https://www.fullfatrr.com/forum/topic68236-45.html
On the top of page 5 there is a photo the 2 different pins. The one on the left is the one that I needed. You can see the difference by looking at them you just need to remove your wheel.
The pads I got from EBC. The wear sensor was also a different version than listed on some sites - I will see if I can find the receipt with the part numbers. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #686985 2nd Mar 2024 6:39pm
luxmoggy
Pin and Spring kit: LR113962
Brake Pad Wear Sensor: LR098988
As I removed the callipers and discs I also needed
4* LR033274 Calliper bolts
2* LR002080 Disc holding screw SDV8 AB MY 2020
Post #686988 2nd Mar 2024 6:48pm
ReggieMac
Thank you for your replies so far, luxmoggy those part numbers and your link to your other post are extremely helpful, thank you! Now I just need to decide on which bloody discs and pads to buy! Big Cry
Post #686990 2nd Mar 2024 7:09pm
luxmoggy
There a few threads on here about pads and discs.
I am liking the EBC ones I brought
Pads: DP62064
Discs: USR1723 SDV8 AB MY 2020
Post #686993 2nd Mar 2024 7:47pm
Gremlin500
You may find this thread interesting, replacing standard with high performance on a TDV6:-
https://www.fullfatrr.com/forum/topic63147...rake+discs “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #686995 2nd Mar 2024 8:04pm
caymanblack
I put Brembos on mine you can find the ones for yours on their site (Part Number ) Then I ordered from AutoDoc. overfinch modified
Post #687009 2nd Mar 2024 10:53pm
luxmoggy
Be careful looking at part numbers on websites even on the Brembo site. For the SDV8 they don’t list the 2018-2022 as an option. I don’t think many were made. These callipers are different to the ones from the 2013-2017. For some parts you can look at the 5L V8 2018-2022. Otherwise it will be the MD computer which can give the correct part number. SDV8 AB MY 2020
Post #687038 3rd Mar 2024 11:53am
ReggieMac
Yeah this is what is making this all so confusing is being able to correctly identify for the 2019 L405 4.4 because, as you say, sometimes they dont list this year and other sites specify 'BREMBO brakes ONLY' or the usual 'Standard' or 'Performance' brakes. It is mind numbing. I suppose I will just have to get a front and rear wheel off and take some picks to be sure OR see if a main dealer will be kind enough to give me part numbers, although the last time I tried that they were very, very unhelpful and wouldn't tell me. Shocked
Post #687048 3rd Mar 2024 12:50pm
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Land Rover have only ever fitted one type of 6 pot caliper from the introduction in 2009 "which superseded the 4 pots" right up to currant day and they are all made by Brembo. The part numbers however do change based on model year, whether painted or not etc, but they are regardless of differing part numbers all the same caliper as long as they have 6 pots. 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #687050 3rd Mar 2024 1:19pm
luxmoggy
If you look at the thread on my front brakes. They changed the 6 pot retaining pins between the 2013-2017 to the 2018 on wards. Both are 6 pot Brembo callipers but are different. SDV8 AB MY 2020
Post #687052 3rd Mar 2024 1:41pm
luxmoggy
Rear pads and springs: LR106326
Rear wear sensor: LR084071 SDV8 AB MY 2020
Post #687056 3rd Mar 2024 2:59pm
I've had issues with non-genuine brake parts in the past, so these days just stick to genuine parts. Nothing super serious, just annoying squealing & excessive dust.
Try Robin @ Duckworth's & give him your VIN number - I was pleasantly surprised at the prices.
https://www.fullfatrr.com/forum/topic55003.html
Post #687078 3rd Mar 2024 6:49pm
Gremlin500
@Reggiemac:
I have had no problems whatsoever with either the Kinetix discs (all four) and Brembo pads I got from eBay in the link above, used them for a year now. Thumbs Up
The calipers were JLR refurb/exchange, again from eBay, absolutely fine:
Post #687090 3rd Mar 2024 8:50pm
