![]() | Home > Maintenance & Mods (L405) > High Performance or Standard Brakes, how can I tell? |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 245 ![]() ![]() ![]() |
Post a picture through the wheel. I believe they are the six piston front calipers. We don’t have the 4.4SDV8 in 🇨🇦.
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 494 ![]() ![]() ![]() |
Hello,
Pin and Spring kit: LR113962
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 220 ![]() ![]() ![]() |
Thank you for your replies so far, luxmoggy those part numbers and your link to your other post are extremely helpful, thank you! Now I just need to decide on which bloody discs and pads to buy! |
There a few threads on here about pads and discs.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1681 ![]() ![]() ![]() |
You may find this thread interesting, replacing standard with high performance on a TDV6:-
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1163 ![]() ![]() ![]() |
I put Brembos on mine you can find the ones for yours on their site (Part Number ) Then I ordered from AutoDoc. overfinch modified |
Be careful looking at part numbers on websites even on the Brembo site. For the SDV8 they don’t list the 2018-2022 as an option. I don’t think many were made. These callipers are different to the ones from the 2013-2017. For some parts you can look at the 5L V8 2018-2022. Otherwise it will be the MD computer which can give the correct part number. SDV8 AB MY 2020
Yeah this is what is making this all so confusing is being able to correctly identify for the 2019 L405 4.4 because, as you say, sometimes they dont list this year and other sites specify 'BREMBO brakes ONLY' or the usual 'Standard' or 'Performance' brakes. It is mind numbing. I suppose I will just have to get a front and rear wheel off and take some picks to be sure OR see if a main dealer will be kind enough to give me part numbers, although the last time I tried that they were very, very unhelpful and wouldn't tell me. |
PDC Member Since: 02 Oct 2018 Location: Warwickshire Posts: 78 ![]() ![]() ![]() |
Land Rover have only ever fitted one type of 6 pot caliper from the introduction in 2009 "which superseded the 4 pots" right up to currant day and they are all made by Brembo. The part numbers however do change based on model year, whether painted or not etc, but they are regardless of differing part numbers all the same caliper as long as they have 6 pots. 2010 RR Autobiography 5.0 SC
If you look at the thread on my front brakes. They changed the 6 pot retaining pins between the 2013-2017 to the 2018 on wards. Both are 6 pot Brembo callipers but are different. SDV8 AB MY 2020
Rear pads and springs: LR106326
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
I've had issues with non-genuine brake parts in the past, so these days just stick to genuine parts. Nothing super serious, just annoying squealing & excessive dust.
@Reggiemac:
