Home > Technical (L322) > I have this auto heater on the car - But it does nothing?
BigJ
United Kingdom 2005 Range Rover Vogue 4.4 V8 Stornoway Grey
I press the remote? Nothing happens?
WHat is meant to happen.... Does it start or something?
Cheers!` Used to have:
2005 FFRR 4.4 Vogue - BRC LPG Conversion & Remapped
Now have:
2008 SSRR 3.6 TDV8 - HSE and plenty of toys
Post #68498 14th Jun 2011 9:38am
might be to warm for it to work maybe.
Post #68500 14th Jun 2011 9:40am
if you sit next to the passenger side front wheel and press the button after a few seconds you should hear a whoosing/mini jet engine noise as it fires up. If it doesn't something is amiss...
Post #68514 14th Jun 2011 11:13am
stu
you should also see the light flash on the top left side of the radio. if you use the remote control you can change it between hot and cold, so even if it's too hot for the aux heater the blower should still come on to let you know the remote has worked. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #68561 14th Jun 2011 5:30pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Make sure the remote is synchronised correctly to the car. I had a T91 remote and that did not work with the older T90 model units. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #68563 14th Jun 2011 5:44pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
or you have the dreaded "low battery" warning....so the car will not allow the FBH to turn on to prevent battery drain.
When you open the driver's door, does the low battery warning welcome you?
Post #68670 15th Jun 2011 3:32pm
