Home > Technical (L322) > I have this auto heater on the car - But it does nothing? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 |
might be to warm for it to work maybe. |
14th Jun 2011 9:40am |
if you sit next to the passenger side front wheel and press the button after a few seconds you should hear a whoosing/mini jet engine noise as it fires up. If it doesn't something is amiss... |
14th Jun 2011 11:13am |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
you should also see the light flash on the top left side of the radio. if you use the remote control you can change it between hot and cold, so even if it's too hot for the aux heater the blower should still come on to let you know the remote has worked. Current: TDV8 (3.6) RRS HSE
14th Jun 2011 5:30pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
Make sure the remote is synchronised correctly to the car. I had a T91 remote and that did not work with the older T90 model units. Tom
14th Jun 2011 5:44pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 803 |
or you have the dreaded "low battery" warning....so the car will not allow the FBH to turn on to prevent battery drain.
15th Jun 2011 3:32pm |
