Home > Maintenance & Mods (L322) > Water ingress into the boot |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4291 |
Check the sunroof drains. Best video I've seen is on the Powerful UK YouTube channel Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
7th Nov 2022 2:09am |
MarkMurphy Member Since: 30 Oct 2022 Location: Cambridgeshire Posts: 16 |
Also, check the pipe for the rear washer/wiper. |
7th Nov 2022 12:35pm |
Tiprat Member Since: 05 Aug 2021 Location: Manchester Posts: 85 |
So just to clarify, the water only comes in when it's raining or when I use a watering can to replicate the rain. So if I pour the water on the roof above the rear passenger door and let it run off, it appears at the bottom passenger side, where the passenger rear corner panel joins the boot floor. I've looked in the audio area, there doesn't appear any water ingress. The sound proofing is dry, the floor area underneath the amp ect seems dry. I've taken the rear pillar cover/speaker cover off and again no water. I've taken the exterior black plastic cover off and cutter sealed the plastic grommets. I've tried to seal the side of the rear quarter window where it sits inside the plastic trim. I've also added some sealant to the top window trim. I can't see any leak coming from the rear wash wipe.
7th Nov 2022 7:04pm |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 841 |
Could it be as simple as the tailgate body seal, they tend to get compressed in certain areas and can allow water to track into the boot area.
7th Nov 2022 7:31pm |
So I seem to have had some success regarding the water ingress, although I'd prefer a couple of heavy downpours before I feel confident that the issue is solved.
9th Nov 2022 9:17pm |
AndyG-RR Member Since: 20 Oct 2021 Location: Great Missenden Posts: 3 |
Thanks for the info, mine has just started leaking into the boot on the passenger side, so a few things for me to check there. |
16th Jan 2023 4:18pm |
NJPovey Member Since: 30 Dec 2020 Location: Sussex Posts: 10 |
My experience was that the LH sunroof drain pipe had partially disconnected from the rear of the sunroof.
18th Jan 2023 11:56pm |
Turned out mine was the rear door seal needed replacing. 2015 SDV8 L405 Autobiography in Santorini Black
21st Feb 2024 5:19pm |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 187 |
does anyone know if the main boot seal has a common fail area or could it be at any point? I also have water in the boot, my lower tailgate carpet is sometimes damp. I havent had time to do the full tests yet as I keep her garaged it hasnt been a high priority but it has to get fixed. Current yokes
21st Feb 2024 9:57pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 329 |
Further info relating to this in these posts:
21st Feb 2024 10:23pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3127 |
My 2004 Old girl is also letting water into the right hand cubicle in the boot (see Photos) - it's not the sunroof as that's covered and the roof lining and area around the wiper is dry and doesn't seem to be letting water in. I will look at the tail gate seal rubber to see if that stops water ingress.
22nd Feb 2024 7:31pm |
Hi James,
23rd Feb 2024 9:46pm |
cheers Matt. Will do as you say |
23rd Feb 2024 10:09pm |
Archieatkins Member Since: 15 Oct 2019 Location: Birmingham Posts: 128 |
Hijacking this thread a little
24th Feb 2024 12:31pm |
