Home > My Range Rover > My first Range Rover some advice please
Page 4 of 5 <12345>
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
Many thanks DrRob the towbar is on the car so all good then.
The key issue was just a battery so that is all sorted. I tried the heated seats when buying and swear they were working, not not any more. Blow cold fine, but no heat, controls all light up. Seems I have some seat stripping to do, had a read on here and it looks expensive fix.
Post #686275 23rd Feb 2024 10:58am
DrRob
Heated seats can take a while to get up to temperature on some motors Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #686282 23rd Feb 2024 12:25pm
DrRob
Some towbars can be a pain to remove if they’ve been on there a while due to rust. Just a heads up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #686283 23rd Feb 2024 12:26pm
Buellie
Thanks, should there be anything under this cover on the passenger side of the boot?
Post #686358 24th Feb 2024 2:38pm
Sonearly
Security wheel nut
Post #686360 24th Feb 2024 2:45pm
Buellie
Thanks, is that all?
Post #686361 24th Feb 2024 2:59pm
DrRob
Nothing in mine. Replace all locking wheel nuts with normal ones. You’ll thank me at 2am in the wet on the side of the motorway when the locking whee nuts strips. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #686383 24th Feb 2024 8:52pm
Buellie
Thanks, where is best to buy 4 standard wheel nuts or are they best purchased from the main dealer?
Post #686425 25th Feb 2024 2:23pm
Kiss My Carbon Footprint
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
I wouldn't do that. They'll happily sell you the LR badly designed product for which the heads will swell upon corrosion induced by moisture ingress.
Better I think to buy an unbranded set of 20 on eBay for under £30
Is what I did.
These of course will fail eventually for the same reason.
But they will have cost you about half what LR will ask for a set.
And as your existing nuts fail over time (which they will), you'll have a stock of replacements, enabling you to continue using the standard wheel brace.
Only alternative I can think of is replace the lot with a set of machined nuts from Wrington.
They're lovely - but expensive.
Whatever you choose to do, take care to buy nuts compatible with your vehicle.
Some eBay sellers will tell you their product will fit all L322 variants from 2001 thru 2012.
This is not true as LR used one design from 2001 thru 2005 and another for models 2006 onward.
The two designs are not interchangeable.
Hope this helps.
Warwick 2011 L322 TDV8 A/b Orkney Grey
2008 Defender 90 XS TDCi Java Black
2002 L322 TD6 Vogue Zambezi Silver (gone but not forgotten)
And one or two bikes - Ok, maybe more than one or two....
Post #686440 25th Feb 2024 4:51pm
Buellie
Thank you that is a fantastic in-depth reply very much appreciated
Post #686441 25th Feb 2024 4:53pm
DrRob
Buy 20 new ones and replace all in one go. You are then starting from new. As above, all nuts swell Big Cry Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #686443 25th Feb 2024 5:13pm
Buellie
Would these stainless one be a good buy?
Are they right for the 2011 model?
https://www.ebay.co.uk/itm/175227362734?it...UO774pa8Yw
Post #686449 25th Feb 2024 6:11pm
I can't tell from the mobile app listing which version these are. So cannot say if they'll fit your car.
And although described as "stainless steel" (which they may well be), the listing also states manufactured to OE specifications.
Implying that they will fail eventually.
If you look closely at photo #2, you'll see that the nuts have separate "caps". Moisture gets under these following attention by mechanic's windy guns, promoting corrosion and causing the caps to swell such that your wheel brace will no longer fit them.
But at 39GBP ?
Far from the claimed saving of 40GBP, I'd suggest they're overpriced by about 30%.
I don't think you'll find machined (and therefore failure proof) items at anything like this price point.
Post #686476 26th Feb 2024 12:15am
Buellie
Maybe these ones in that case?
https://www.ebay.co.uk/itm/134547735083?_t...p_homepage Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #686495 26th Feb 2024 3:33pm
Looking at the eBay item description, the seller says "For Range Rover 2001-2012".
No such product exists because LR used two different wheel stud / nut designs over that time. As I say LR used one design from 2001 thru 2005 and another for models 2006 onward.
We cannot say for which period this item is suitable.
Suggest pick one for which the eBay description specifically states compatibility for the period in which your model year falls, for a price that you can stomach and offered by a seller with solid feedback.
And then treat them as the consumable that they are. Replace them as they fail. No point in replacing all of your existing wheel nuts regardless of condition because unless they've already failed, is hard to know what point in their inevitable decline they may have reached. And the replacements will also fail eventually and unpredictably anyway.
Better to keep a socket wrench in the car along with an oversize socket.
Or just make sure your AA / RAC (or whatever) membership is current.
Hope this helps.
Post #686517 26th Feb 2024 7:12pm
Page 4 of 5 <12345>
