![]() | Home > General > What Did You Do In Your Full Fat Today |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Passed MOT for yet another year! Had her for nearly 11 years now😃 Previous cars:
RobErica Member Since: 16 Nov 2023 Location: Loosbroek Posts: 38 ![]() ![]() |
jamiej Member Since: 01 Dec 2023 Location: Surrey Posts: 52 ![]() ![]() ![]() |
Got the old girls MOTd with a pleasantly short list of advisories |
Big Vee Member Since: 27 Dec 2023 Location: Lancashire Posts: 20 ![]() ![]() ![]() |
Tried out my homemade wheel fitting guides, worked as intended |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 219 ![]() ![]() ![]() |
Passed MOT with no advisories |
SeldomSeenKid Member Since: 24 Jan 2024 Location: Glasgow Posts: 72 ![]() ![]() ![]() |
First MOT pass with me.
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 ![]() ![]() ![]() |
My wife took ours to her parents over the weekend.
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 94 ![]() ![]() ![]() |
New coolant bottle (resolving the "low coolant" warning).
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2585 ![]() ![]() ![]() |
Yesterday I finished the job started the day before to replace the leaking radiator and all the hoses and plastic in the V including the hoses to the EGR cooler. I also fitted the sender unit for an oil pressure gauge. Lots of the plastic fittings/pipes broke when trying to disassemble, including the known fragile bleed fitting on top of the water outlet. However I retained my brass fittings and standard hose for the bleed line from the donut to the top radiator hose to avoid breaking the connection to the top hose again in a couple of years' time. |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 645 ![]() ![]() ![]() |
Fixed the annoyingly loose rear bumper protector trim that'd got the end lifting. Removed it, the end moulded plastic tab was missing, probably broke off years ago if it was ever there, cut one of the middle tabs in half and used a combination of hidden drill holes and Gorilla 2 pack resin glue to secure it in place. Left overnight on the radiator.
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Replaced the driver seat base foam with a new one |
Fixed the Seat Heater with the new peltier from Aliexpress, £40 after getting the parts back from the guy who was supposed to fix it but that all fell through.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1627 ![]() ![]() ![]() |
……….. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3879 ![]() ![]() ![]() |
Went to get KFC Geoff |
