Home > My Range Rover > My new L322...
rryan
United Kingdom 2010 Range Rover Vogue TDV8 Buckingham Blue
My new L322...
Hi all,
I'm finally the proud owner of a 2009 Buckingham Blue 3.6 TDV8 L322 having been scouring the wealth of knowledge of this site for a while.
My first two priorities will be a brake squeal and I've the odd persisting restricted performance with EML indicating a P0405 fault, EGR circuit A. I've a couple of questions if I may!
Re brakes - first plan is to strip, clean, lube and reassemble but failing that, I'll replace. I'm now on the hunt of anyone here who is offloading a 3T trolley jack and stands before I head out and get a new one.
EGRs... I want to capture this asap and my plan is simply to blank. On this topic is there a preferred way ie remove the pipe and plug each end or using just the one "MOT friendly" plate? I'm not fussed re MOT as you can't see under the cover.
I'll just then be on the look out for someone local armed with knowledge and an EGR map... I'm in the New Forest, Hampshire so please do reach out.
Anyhow, those are the priorities, here's a picture for good measure and you'll likely be hearing from me soon!
Cheers all.
Post #685911 18th Feb 2024 2:37pm
rryan
And another one just to show off the New Forest sun this afternoon!
Post #685913 18th Feb 2024 2:44pm
rryan
PS... I'm also on the lookout both on here and the disco forums for an IID tool.
PPS... oh and coincidentally this post also gets my three. Whistle
Post #685914 18th Feb 2024 2:45pm
GregPrice80
United Kingdom 2010 Range Rover Autobiography Black TDV8 Barolo Black
Nice looking car. Always liked a Range Rover in blue. Good luck with ownership going forward.
Post #685973 19th Feb 2024 4:22pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Good choice of colour; my 4.4 is the same !
WRT brake squeal: I had this and spent ages cleaning & lubing brake pins etc….. it turned out to be crap quality brakes pads. I put in some EBC greenstuff pads and haven’t had a problem since.
Make sure your pad squeal retainer springs are correctly oriented; they should butt against the pad at the top but it’s easy to mistakenly fit them reversed.
 TDV8 4.4 2012
Post #685979 19th Feb 2024 5:09pm
JayGee
As other have said it's hard to beat that exterior and interior colour combo - it just looks effortlessly classy and timeless. Just buy a GAP tool new as you can easily sell it later for not much more than you paid for it now so think of it as a safe investment and you can then do a DIY EGR map-out and be on top of all your diagnostics. 2012 TDV8 Vogue (L322)
Post #685987 19th Feb 2024 6:40pm
rryan
@Ramblin Man I have a feeling this may well be the case, pads added to the shopping list! Great tip re the clip too thank you, good to know.
@JayGee It comes in the post tomorrow so you may well be on the right track there. Cheers![/quote]
Post #686104 20th Feb 2024 9:41pm
DrRob
Use site forum Advanced Factors in Southampton for parts. Discount online. Code is AF4LRP
Recommended LR specialist in the region in my signature below 👇 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #686106 20th Feb 2024 9:49pm
