Home > Technical (L322) > Seems one of my rear brake stop lights has failed today.
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
The only detail given in my manual - 2012 V8TD Westy is that its LED. Does anyone know if its a single bulb replacement or part of the main LED cluster there that needs replacing? seem to be going round in circles on the internet!
Sad
Cheers
Dave
Post #685764 16th Feb 2024 11:30am
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
Replace full unit on the LED taillights unless you're brave and want to dismantle the cluster entirely. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #685772 16th Feb 2024 1:04pm
JayGee
Have you checked the wiring to see if it's not a bulb? As said it's a whole unit replacement unless you fancy splitting it apart . 2012 TDV8 Vogue (L322)
Post #685773 16th Feb 2024 1:08pm
Kot
My daughter's Freelander2 had a similar issue (yes I know lol but maybe worth a try )
It still didn't work for us. So then used AP200 Code reader and .reset P1703-00 intermittent "Brake switch out of self test range"
P0504-62 intermittent "Brake switch A/B correlation
It happened after passenger fuse box cover was dislodged so suspect a loose wire? Anyway it worked so check and reset DTC's
Apparently the individual circuits have some sort of transistors that protect the module if a fault occurs? maybe its same with FF? 2018 SE SDV8 4.4 Byron Blue
Post #685776 16th Feb 2024 1:31pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
I have a passenger side rear light unit off a 2012 L322 Westminster that I replaced with an US spec one to match the drivers side. Let me know if that would be of interest. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #685777 16th Feb 2024 1:37pm
Nylands
Stop light
Thanks everyone.
The unit replacement then is the way to go if its not a electrical fault. As the Powerful UK option of a replacement LED cluster which was about £100 a year or so ago is no longer available, a whole unit on ebay is an option at £85.
Just had a call from my garage to say the car won't be ready until Monday now as the job of replacing the drive belts has hit a problem with the breakage of a small rubber pipe. Not an uncommon outcome in stripping down apparently. What can you do?
Thanks
David Big Cry Big Cry
Hi All
Just printed these suggestions in full as they will help should I, the amateur, need to fix such a future break at home!!
Thanks again everyone.
Post #685783 16th Feb 2024 3:16pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Guessing that’ll be the famously fragile coolant return pipe that runs off the large coolant hose at the front / top of the engine.
Can usually be repaired using some form of ‘stent’ opposed buying the whole set of related pipes 👍
https://www.fullfatrr.com/forum/topic48509.html?highlight=stent Jonathan
2007 Defender 90 XS Hardtop
Post #685784 16th Feb 2024 3:26pm
Nylands
I think your right about that pipe you mention Jonathan but at least leaving it there to finish the job I should get it back Monday and earlier in the day at that. Fingers crossed that nothing else goes wrong and the replacement pipes comes at £100, plus VAT I suppose.
Cheers
David
Post #685786 16th Feb 2024 3:48pm
Nylands
Update and question
Hi All
Collected the car from the garage yesterday but waiting for the bill which hopefully is reasonable. Strangely the brake light fault has disappeared and is working properly again? Whilst welcome anyone else experienced something similar? Also on the return journey the smart key warning appeared on the dash - battery low! Is the car manual incorrect as it states insert new battery + side up? Mine only works "negative" side up. I know I have a functioning key fob but isn't life confusing enough?
Onwards and Up.
Cheers
Dave
Post #686121 21st Feb 2024 10:20am
