Home > Technical (L322) > Seems one of my rear brake stop lights has failed today. |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 |
Replace full unit on the LED taillights unless you're brave and want to dismantle the cluster entirely. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
16th Feb 2024 1:04pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3241 |
Have you checked the wiring to see if it's not a bulb? As said it's a whole unit replacement unless you fancy splitting it apart . 2012 TDV8 Vogue (L322) |
16th Feb 2024 1:08pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1217 |
My daughter's Freelander2 had a similar issue (yes I know lol but maybe worth a try )
16th Feb 2024 1:31pm |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 362 |
I have a passenger side rear light unit off a 2012 L322 Westminster that I replaced with an US spec one to match the drivers side. Let me know if that would be of interest. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
16th Feb 2024 1:37pm |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 194 |
Thanks everyone.
16th Feb 2024 3:16pm |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 869 |
Guessing that’ll be the famously fragile coolant return pipe that runs off the large coolant hose at the front / top of the engine.
16th Feb 2024 3:26pm |
I think your right about that pipe you mention Jonathan but at least leaving it there to finish the job I should get it back Monday and earlier in the day at that. Fingers crossed that nothing else goes wrong and the replacement pipes comes at £100, plus VAT I suppose.
16th Feb 2024 3:48pm |
Hi All
21st Feb 2024 10:20am |
