Home > Technical (L322) > Where is my coolant leaking from, any ideas? |
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 178 |
Unsure if the 3.6 is the same coolant pipe wise but my 4.4 l322 had stainless pipes running down the n/s just above the chassis a several pin holes appear under pressure and leaks. There is a post somewhere on here if you do a search and replacement advice and cost 2016 4.4 diesel |
10th Feb 2024 11:00pm |
Jorrocks Member Since: 13 Feb 2012 Location: Shropshire Posts: 55 |
Thanks! Yikes, I think you’re correct. £700 for that part is a complete p***take. I can get a fabricator to make me a copy for about a quarter of that. Then there’s the question of why JLR designed a part for the cooling system that isn’t resistant to coolant🤬🤬! 2018 L405 4.4 SDV8 Autobiography
11th Feb 2024 10:43pm |
If you search further you will see that someone repaired there’s with a length of rubber hose. Which is exactly how I did mine. Bought about a three metre length,used less than a quarter of a metre. But fixed the leak all the same 2016 4.4 diesel |
11th Feb 2024 10:51pm |
