![]() | Home > Maintenance & Mods (L322) > Ipad or tablet mount |
madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 104 ![]() ![]() |
I like your wood finish! |
th3chainrule Member Since: 24 Sep 2022 Location: East Posts: 16 ![]() ![]() |
Looking to replicate your phone mount in my vehicle; how did you get it to securely mount in that slot to the right of the head unit? |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 647 ![]() ![]() ![]() |
Hi,
The mount itself is here: https://www.ebay.co.uk/itm/203792454424?var=504232705201 The power lead / media cable is long enough that when not in use it lays atop the steering column. In use the cables quite hidden as my phone attached to the maj mount in the lower right corner of the pic. One of these days I'll re-route it so it comes in from the windscrren side. In the bottom picture you can see what it looks like from the outside. Reason I went with this way ant the mag mount is I can quickly just grab it when parking up and stuff it under the seat out of sight without attracting any attention. Andy Fuji White / Jet 2012 4.4 TDV8 Westminster |
RoamingRange Member Since: 28 Jun 2015 Location: Cheshire Posts: 7 ![]() ![]() ![]() |
Nice! How is it attached / standing? Do you have a picture from behind? I’d quite like to do the same with an iPad mini. |
RogueRanger Member Since: 03 Jan 2024 Location: Kent Posts: 116 ![]() ![]() ![]() |
The best retrofit by far imo. Though I do wonder why so many want a big screen in the car. I use Google maps on my phone, stream music via bt to the aux input and the phone connects via a 2010 L322 bt module in the boot. What more would I gain from a similar retrofit? And how would I get this look? Thanks! Des 2005 (2006 MY) L322 4.2sc Java Black, 2010 facelift conversion 1965 Lenham Lemans GT 1310 , Gulf Racing blue, FIA spec and road legal 2018 F56 Mini JCW, Thunder Grey/Black, Mulgari St2 tuned, FMIC, short shifter and Eibach springs |
I use the same setup as you at the moment, but I have a spare iPad mini kicking around and it would be nice to have a bigger screen on the dash for obd apps, bigger maps, etc so I may as well use it. But I like this retrofit. Curious to know what it’s leaning against. |
Hi Roaming range. There is a bracket behind which attaches to the screen. I meant no big visible bracket thing at the front of the dash. I’ve moved on from this now and have taken the central vents out ( they are not missed) and set the device in the recess. You can get power from running a lead under the dash top and down to the fusebox. I made a little panel to block out the rest of the vent hole. A picture attached. I think this looks even better. Dear Rogue Ranger. Everyone to their own! The main reason is I find it difficult to see SatNav on the phone and also control of Spotify etc music. I think the law now is that you can’t touch your phone even if for music/satnav etc |
That’s correct Madness. Or may I call you Madders?
Thanks for the compliment.
^^^I think the law now is that you can’t touch your phone even if for music/satnav etc
I thought that you can only use a fixed/clamped phone hands free ie voice control or bluetooth. I have always assumed that but maybe I’m wrong.
I looked it up as I had no idea whether the rule is no touching or no handling. It’s no handling.
Hi again,
