Home > Technical (L322) > 2012 RR full fat 5.0 V8 non SC
DEEBEE(060)
United States 2012 Range Rover HSE 5.0 V8 Orkney Grey
So I have a leaky valve cover Left side. Does this require the removal of the injectors to remove the cover. Any advice appreciated. TIA
Post #684853 6th Feb 2024 4:05am
dhallworth
It does unfortunately.
If there’s 1 you can’t get out you can twist the body of the injector around 90 degrees but I don’t believe you’ll be able to manoeuvre the valve cover around all 4 of them. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #684907 6th Feb 2024 9:38pm
