Home > Maintenance & Mods (L405) > Water getting in RHS rear 1/4 panel
rstoughy
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
I have some water getting in the RHS rear panel in the boot.
At 1st I thought probably sun roof drain however that goes down the C pillar and this is more the D pillar. I also thought it could possibly be the rear light seal however I can see drops above the height of the light.
Any common things that cause this I can use as a starting point?
No water up to or in front of the aux battery.
Any suggestions???
Cheers,
Paul
Post #684816 5th Feb 2024 5:51pm
knwatkins
Wild, random guess - roof antenna? I believe the cables from the antenna are routed down the rear right hand side of the boot, down the D pillar. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #684845 5th Feb 2024 9:11pm
lambo911
United Kingdom 2016 Range Rover Autobiography SDV8 Barolo Black
Yes, it can get in via the antenna 2016 AB SDV8 Barolo black
Post #684880 6th Feb 2024 3:07pm
rstoughy
Thanks guys planning on pulling panels at the weekend and having an investigation so will pop down the rear of the roof lining and check the antenna seal.
Thumbs Up Thumbs Up
Post #684954 7th Feb 2024 1:16pm
