Home > Maintenance & Mods (L322) > How far to go with replacing ancillaries ? |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6740 |
As a veteran of 3 alternator replacements, I’d say that unless it’s been changed already, that would be top of my list!
5th Feb 2024 7:44pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2554 |
I replaced the water pump and belts and pulleys when replacing the alternator and I'm now about to replace all hoses and the water outlet/thermostat housing because the radiator has a slow leak at the join of the top tank for hopefully another 10-12 years of reliable usage. |
5th Feb 2024 7:59pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 812 |
Do you have part numbers for “all the hoses” ? |
7th Feb 2024 5:47pm |
Hoses and the 2 water outlet parts that I've ordered. I'm not replacing the heater hoses that connect at the edge of the donut because I consider that they haven't been subjected to the engine heat of the rest.
7th Feb 2024 8:08pm |
