![]() | Home > Technical (L322) > Blown mega fuse again |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
if it was ok before the new starter then thats the obvious place to look first.. ... - .- -.
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
Fuses don't usually blow with an earth lead not grounding correctly, if anything nothing would happen as the loop would be open circuit, you might get the click of the solenoid, but the starter wouldn't throw.
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 169 ![]() ![]() ![]() |
+1 to check starter motor as most likely culprit. Good luck 2012 4.4 TDV8 Vogue Santorini black ivory leather |
Clarky595 Member Since: 18 May 2023 Location: West Sussex Posts: 2 ![]() ![]() ![]() |
After the new starter was fitted it still wouldn’t start and was told to check mega fuse and replaced the fuse and bingo she started .But went to fire her up today and click ….. |
