Home > Maintenance & Mods (L405) > Addition to low beam headlights
Page 1 of 3 123>
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
Any ideas?
Not really happy with the quality of lighting when on the low beam mode.
Can you fit a light bar?
Is it legal?
Post #683804 24th Jan 2024 8:48pm
DrRob
Fit Bevinsee LED replacement bulbs 👍🥳 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #683818 24th Jan 2024 10:35pm
SFM
Can you do that with xenon’s ?
Post #683833 25th Jan 2024 1:25am
yes you can....theres a few threads re this..
cam tec craig has fitted a lightbar behind his front grille on one of his FF's, do a sesrch. ... - .- -.
Post #683840 25th Jan 2024 7:48am
Gremlin500
I think the light bar would only be legal off-road.
There’s loads of LED bulb upgrades on eBay and AE as mentioned in the other threads. “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #683844 25th Jan 2024 9:42am
SamThomas
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
- as if there is not enough glare from factory fitted LED headlights..............
Unless the L405 headlights are inferior to the L322 then there is no need to modify what you have & of course all those that have modified their headlamps have informed their insurance companies......
Post #683850 25th Jan 2024 10:48am
my personnel view and that of others is that the l405 xenon headlights 'are' inferior to the L322 lights... ... - .- -.
Post #683851 25th Jan 2024 11:28am
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
I fit LED bulbs last week. There is no additional glare as they are projector headlights and are properly aimed. They we under $30 Canadian from AliExpress. Much better than Xenon, instant on, and bright. I have been running and retrofitting Xenon headlights since 2000.
Those that retrofit LED bulbs in reflector style headlights or improperly aligned projector headlights are the cause of the problem.
I would not add an LED light bar behind the grill as I have on other vehicles. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #683875 25th Jan 2024 4:25pm
SamThomas
In that case you can alway drive in a manner/speed withing the limits of the factory fitted lights or get your eyes tested..........
Post #684206 29th Jan 2024 12:21pm
SamThomas
Virtually all LED light sources produce glare to a greater or lesser degree.
Post #684207 29th Jan 2024 12:23pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
Glare from headlamps essentially is light escaping from the designed pattern. Unfortunately a lot of people are putting high power LEDs into headlamp bowls that were never designed for them.
The headlamp and, protective lens and parabolic mirror are very carefully designed to match a specific bulb type and radiation pattern, if you then fit another type of bulb only a fool would assume it will work as designed, pot luck perhaps, but poor all the same.
Sure it's going to be brighter if it generates high lumens but the light pattern is all over the place, it may conform to the set cutoff rules but there will probably be considerable stray light escaping, thus dazzle or glare.
For those that wear prescription glasses, prisms, contact lenses or IOL implants the impact can be quite blinding driving at night.
If you can't see at night with D3S bulbs from a premium brand on the Range Rover, you probably need your own eyes testing.
So please stop being obsessed with brightness and spare a thought for those of us who are over the age of 3.
Rant over, back in the box Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #684210 29th Jan 2024 12:44pm
supershuttle
I had an L322 and now an L405 yes the headlights aren't as bright but I think they are more than adequate and I'm over 70 and wear glasses so my rallying days are over (its the wrong sort of car anyway). I used to have Cibie and Marchall spotlights for hammering through forestry sections at breakneck speeds. Obviously crashed and overturned a few vehicles but more interested in wafting along in serene comfort now. Geoff
Post #684224 29th Jan 2024 3:37pm
Malbro
United Kingdom 2016 Range Rover Autobiography SDV8 Carpathian Grey
?si=GTCwD075YKjugXA0
Looks interesting
Post #684266 29th Jan 2024 10:22pm
Vogue
The pre facelift L405 headlights are dreadful - the L322 are far superior. The pixel / matrix L405 lights are though in a different league 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #684275 29th Jan 2024 11:11pm
SamThomas
AndyRoo wrote:
Hi,
Very well said - I wonder how many of the proponants of fitting LED's to lights NOT designed for them have had their own eyes tested recently, especially up to vocational driving standards ?
Post #684277 30th Jan 2024 1:12am
Page 1 of 3 123>
