Home > Technical (L322) > FBH Cabin Temperature - Quick Question |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3235 |
Batteries are not expensive so if it's of unknown age maybe best to replace it.- plenty of info on here of how-to and what type. 2012 TDV8 Vogue (L322) |
11th Jan 2024 2:12pm |
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 79 |
Cheers, I think that would be a good idea. |
11th Jan 2024 6:54pm |
https://www.tayna.co.uk/car-batteries/types/019-agm/ 2012 TDV8 Vogue (L322) |
11th Jan 2024 7:11pm |
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 |
Looking at the number on the left I have the same heater in mine. It's 5 KW so should be enough for reasonable heat here (Maybe gets to minus 15 once or twice but usually around +5 to -5 on average here) But how do you manage to get the fan running after 10 minutes ? Mine just turns on as soon as I press the remote ? Cheers, Ard |
15th Jan 2024 6:32pm |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 193 |
I mean would be good if:
15th Jan 2024 7:16pm |
Okay thank you. |
15th Jan 2024 7:49pm |
Well, maybe its even possible somehow, but very hard. Even if replace Webasto LR ECU with analog one. Analog ECU can control vehicle fan via analog signal (+12V on pin 4) after coolant has reached a temperature of 30°.
15th Jan 2024 8:31pm |
I just tried to pair my T91 remote today, is there any indication that it has been done correctly or not?
29th Jan 2024 10:22am |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 564 |
Hi, oddly people think the remote it's for the FBH heater, it isn't. The remote is for the climate control.
29th Jan 2024 11:05am |
Thanks Andy, so the only way to check if pairing was correct is to see if it initiates the FBH? |
29th Jan 2024 11:08am |
Hi, I don't know that there is actually a method for checking the pairing because that would entail getting into the boxes and checking the respective codes align.
29th Jan 2024 11:19am |
Thanks Andy, great information I did not do the stuff with the ignition... I will give this another crack! |
29th Jan 2024 10:09pm |
