![]() | Home > Technical (L322) > FBH Cabin Temperature - Quick Question |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3231 ![]() ![]() ![]() |
Batteries are not expensive so if it's of unknown age maybe best to replace it.- plenty of info on here of how-to and what type. 2012 TDV8 Vogue (L322) |
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 79 ![]() ![]() ![]() |
Cheers, I think that would be a good idea. |
https://www.tayna.co.uk/car-batteries/types/019-agm/ 2012 TDV8 Vogue (L322) |
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 ![]() ![]() ![]() |
Looking at the number on the left I have the same heater in mine. It's 5 KW so should be enough for reasonable heat here (Maybe gets to minus 15 once or twice but usually around +5 to -5 on average here) But how do you manage to get the fan running after 10 minutes ? Mine just turns on as soon as I press the remote ? Cheers, Ard |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 193 ![]() ![]() ![]() |
I mean would be good if:
Okay thank you. |
Well, maybe its even possible somehow, but very hard. Even if replace Webasto LR ECU with analog one. Analog ECU can control vehicle fan via analog signal (+12V on pin 4) after coolant has reached a temperature of 30°.
I just tried to pair my T91 remote today, is there any indication that it has been done correctly or not?
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 564 ![]() ![]() ![]() |
Hi, oddly people think the remote it's for the FBH heater, it isn't. The remote is for the climate control.
Thanks Andy, so the only way to check if pairing was correct is to see if it initiates the FBH? |
Hi, I don't know that there is actually a method for checking the pairing because that would entail getting into the boxes and checking the respective codes align.
Thanks Andy, great information I did not do the stuff with the ignition... I will give this another crack! |
