Home > Technical (L322) > Rear suspension knocking
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Another week and another problem Rolling Eyes This week its a knocking noise coming from the offside rear when going over speed bumps and any general road surface - they all seem bad after the winter we've had Sad
Anyway - had a quick crawl underneath and had a look at the anti-roll bar bushes and they seem to look just fine as do several of the lower bushes on the wishbone - so anyone had this before and what is the likely culprit ?
Thanks in advance Wink
Post #64212 16th May 2011 8:12pm
jonminns
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
Unsure to be honest, i have this issue on the drivers front so interested as to your progress 2008/58 FFRR 3.6 TDV8 Vogue
Post #64213 16th May 2011 8:14pm
dan_uk_1984
I've never had success with a "visual inspection" of bushes etc. The RR is so heavy you just cant detect play. It's best when it's up on a ramp and you can put a 3 foot bar between the joints to detect play, or better still when the wheels are hanging. Any decent garage should do this.
What's your mileage? I would bet it's bushes on wishbones or roll bar links myself...
D
Post #64215 16th May 2011 8:17pm
mercs600
I know the front has ball joints which are prone to wear and also anti-roll bar linkages which can cause this problem ! Had the same on my Merc S class and fitted 1 x cheap linkage on one side and 1 x genuine Mercedes linkage on the other - the genuine one lasted over 6 years - the cheap one 3 months ! Don't buy cheap parts it's not worth it in the end as you do the sam job twice Wink
Post #64216 16th May 2011 8:20pm
I would echo what Dan said. Get a jack under the offending corner and give it a good tug in all directions. The dodgy bush should show up when their is no load on it.
Post #64221 16th May 2011 8:51pm
mercs600
Fitted the new antiroll bar linkage and had a good tug and pry on everything whist I was there - fault/noise still there and nothing evident Confused Does the rear shocks have bushes at the top ? could these wear and how easy is it to remove a shock absorber ? Wink
Post #68368 13th Jun 2011 10:00am
The top and bottom bushes that attach the hub assembly to the top and bottom wishbones are prone to wearing, check them.
Post #68372 13th Jun 2011 10:36am
mercs600
Thanks - I will have a look this weekend coming - if the rain ever stops Sad
Post #68378 13th Jun 2011 10:55am
stu
rain in sunny yorkshire!!!... Laughing Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #68421 13th Jun 2011 5:23pm
mercs600
Suspect it's the shock absorber - are they easy to change ?
Post #68867 16th Jun 2011 6:47pm
Shouldn't be difficult, looks like 1 bolt top and bottom, the top will be inside the boot area. You might have to remove 3 bolts from the top mounting plate but I wouldn't think it necessary.
Post #68882 16th Jun 2011 7:30pm
